Anyone know what this is?
Old Aug 23, 2013 | 10:36 PM
Ripperg9's Avatar
Ripperg9
This attaches between between the manifold and the exhaust pipe on the drivers side. 352 V8 1965
Does not appear to be functioning.
Old Aug 23, 2013 | 10:40 PM
rogue40's Avatar
rogue40
Designed to restrict exhaust flow to assist in warm up. I recycled mine.
Old Aug 23, 2013 | 10:53 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
So what else is new?
D3TZ-9A427-A (replaced C5TZ-9A427-D) .. Heat Riser Valve / Obsolete ~ 10 available NOS
Valve contains a flapper that is notorious for getting stuck in the open position.
1965/67 F100/350 352 / 1973/74 F100 360.
Old Aug 24, 2013 | 12:23 AM
Ripperg9's Avatar
Ripperg9
Mine is stuck open.
What do you think should i put it back as is, replace part, or is there a way to modify to run without it? The bolts are to long to just leave it off.
Old Aug 24, 2013 | 07:41 AM
Buzz44's Avatar
Buzz44
Mine is stuck open.
Put it back in and don't worry about it as long as it is in the stuck open position. You already have a very restrictive exhaust system with the old cast iron exhaust manifolds on that motor. It will not affect anything. If you live in cold weather it may take slightly longer to warm up when first started.
Old Aug 24, 2013 | 09:03 AM
raytasch's Avatar
raytasch
Believe Nothing
Yeah, put it back in. Someone may want to free it up during a restoration someday. If you have it in your hand, go ahead, spend the time to free it and you can hear it rattle as it works. OTOH, if all the parts are there, put it FS, someone will buy it.
corkinaz
Jun 8, 2019 07:30 AM
Camper Special Gene
Jan 25, 2014 08:07 AM
1968Lew
May 16, 2011 06:36 PM
37 Ford guy
May 9, 2009 05:45 AM
JefflovesF250s
Feb 11, 2005 02:21 PM
