6.0 dead with no codes
Old Oct 19, 2012 | 11:19 PM
  #31
m-chan68's Avatar
m-chan68
Originally Posted by Josh Baker
it was a slow death.....
driving and then I lost throttle response and after about a minute of rough idol it died.
I'm beginning to think your fuel pump is weak or faulty.
Old Oct 20, 2012 | 09:21 AM
  #32
Josh Baker's Avatar
Josh Baker
Okay I did the bubble test and nothing.... anyway I checked the fuel pump like you said and it filled up super fast. should i test the pressure on it?
I also double checked all my fuses and they look good as well.
The injectors make all sorts of noise when I turn the engine to run. about 30 seconds or so i think could be a minute but they make a lot of clicking for sure but I can't tell if they all are clicking or just most of them.
Old Oct 20, 2012 | 06:55 PM
  #33
Josh Baker's Avatar
Josh Baker
okay so on a whim I hooked up my block heater and now with my engine warmed up I am getting some way way different results as far as my ICP readings go..... I can't get over 400 PSI now when I try to start.
is that a hpop or HPO leak? and is there a test I can perform to verify?
Thanks in advance for the advice.
Josh
Old Oct 20, 2012 | 08:47 PM
  #34
BLADE35's Avatar
BLADE35
Post ICP and IPR% during Crank
400 ICP isnt enough to start 600ICp is Ideal
At 400psi ICP the FICM wont turn On to fire the Injectors
Old Oct 20, 2012 | 08:51 PM
  #35
BLADE35's Avatar
BLADE35
It seems like ICP is all over the place is the plug oil soaked
Might be a ICP wiring issue throwing it out there
Old Oct 21, 2012 | 06:29 PM
  #36
Josh Baker's Avatar
Josh Baker
Okay this is now after the IPR valve has been replaced and with the engine warmed up on my block heater:
KOEO:
IPC 0
IPV .23
IP%: 14.4
Cranking:
IPC: low 400's
IPV .5-.6 range
IP% Peaked in the 70% range
I pulled the ICP and tried to start it as well and the IPC numbers shot upto the 900's but the IPV didn't go up and IP% went up as well and still no start.
I believe this is pointing to a HPOP or HPO leak. next test is the HPO air leak test, Correct?
Anything I should be looking for specifically that the guides don't mention?
also what am I looking at cost wise if the leak is under the valves for parts to repair and since I am that far in are there any modifications I should be making on it to improve reliability?
Josh
Old Oct 23, 2012 | 10:36 PM
  #37
Josh Baker's Avatar
Josh Baker
okay so I have the valve covers off and the passenger side standpipe is 12mm which means it has been replaced, correct? the dummy plugs are both original but the o-rings are intact on both. The driver side standpipe has both 0-rings intact and look to be in good shape. I am going to get new ones but it looks like dummy plugs and standpipes are in good order and not the cause of my lack of HPO pressure. anything else I look at while I have the valve covers off? All signs seem to be pointing to HPOP now, I think.
passenger side standpipe coming off tomorrow when I get a 12mm allen. (could just 1 bad o-ring cause a big enough leak for the HPO system to not be able to build enough pressure?)
i am not sure what I should be looking for beyond the dummys and stands so any help would be awesome.
Josh
Old Nov 7, 2012 | 07:00 PM
  #38
Josh Baker's Avatar
Josh Baker
Hpop, Dummy plugs and standpipes replaced and it started right up!
Thanks to everyone that helped me along the way!
Old Nov 7, 2012 | 07:54 PM
  #39
BLADE35's Avatar
BLADE35
Sweet Thanks for posting the outcome reps given
Old Nov 7, 2012 | 08:22 PM
  #40
m-chan68's Avatar
m-chan68
And the part highlighted in bold red is the part that likely fixed your issue, hence why your ICP readings were all over the place. It is very well known that the '03/'04 pumps are overall weaker than the '05 and up pumps. The ones I've replaced that were bad I found, if you tried to spin the gear by hand you would hit a dead spot.
Old Nov 7, 2012 | 10:00 PM
  #41
Yahiko's Avatar
Yahiko
M-chan,
When they replace the HPOP on the '03/'04 is the newer pump
better and the one it was built with?
Sean
Old Nov 7, 2012 | 10:02 PM
  #42
m-chan68's Avatar
m-chan68
Originally Posted by Yahiko
M-chan,
Sean
To be completely honest Sean, I don't know but I very much doubt it.
Old Nov 7, 2012 | 10:40 PM
  #43
Yahiko's Avatar
Yahiko
M-chan,
Thanks for the quick answer.
Not that I have to worry about this having an 06 I just wanted
to know. You think that they would of upgraded the part.
Just incase I end up working on my friends 03 F250.
Sean
cabloom300
Oct 11, 2017 06:42 AM
jdneal88
16
Jan 2, 2017 12:35 AM
f150crewcab
May 20, 2012 07:37 AM
jmaskew
Aug 21, 2011 05:47 AM
Creampuff99
Jun 2, 2011 09:22 PM
