5 speed for ford 400 long block
Old 10-10-2012, 10:08 PM
younggun2012's Avatar
younggun2012
younggun2012 is offline
NEED HELP!!!!!!!!
i have a 1968 ford f100 ranger and i am looking to put a ford 400 long block with a five speed is my dream. However, I am having trouble finding any performance options for the 400 as well as a 5 speed that will bolt up to the 400 any ideas and input would be amazing thanks
Old 10-10-2012, 10:16 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,596 Likes on 1,301 Posts
Performance options for the 400 are mostly aftermarket as it was never a performance engine as OEM. You can find everything you need to turn it into a firebreather here:
TMeyer, Inc. Precision Automotive Machining
The minimum to make it a runner is a cam change, along with whatever the cam change requires spring wise etc.
As for a 5 speed, the ZF 5 speed will bolt up, but some mods are needed to deal with the pilot bearing. More than you'll ever want to know here:
https://www.ford-trucks.com/forums/1...zf-tranny.html
If you want a performance 5 speed, you are looking at a TKO or T56 6 speed, with an aftermarket bell.
These folks will be more than happy to help you in your quest:
Modern Driveline - TREMEC T5 / TKO Transmission Conversion - 5 speed & 6 speed solutions to swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
Having said all that, what engine is in it and have you ever heard of the 351w?
Old 10-10-2012, 10:30 PM
younggun2012
right now there is a 352 big block which came in the 67 but not the 68 im thinking it has a reman plate on it so its a fairly new motor and runs ok but with the factory 3 on the tree. It screams any time i take it on the interstate and do alot of traveling back and forth on the interstate plus i love 5 speeds
Old 10-10-2012, 10:34 PM
85e150's Avatar
85e150
85e150 is offline
Do you want a truck trans or performance?
Either way, if that engine is a good runner and you are satisfied with the power, you could adapt a ZF or performance trans to it for far less than the engine swap.
Old 10-10-2012, 10:38 PM
younggun2012
honestly in the middle i want a good bit of power but i also drive the truck everyday because i love old trucks. i also have complete 400 that i am just put on the engine stand and am going to tear into to see the condition i dont need a monster but would like the truck to have a little more power the 352 runs like a top and fires every time but i would like to have a bit more power and torque
Old 10-10-2012, 11:00 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Originally Posted by younggun2012
NEED HELP!!!!!!!!
Scroll down to the bottom of this thread. I included some information and a performance build for the 400..: https://www.ford-trucks.com/forums/1...l#post12325576
Here's another one from Hot Rod magazine. How does 556 lb-ft of torque and 496.7 hp sound to ya?: How We Got Over 497 hp from Ford's 400M Engine - Hot Rod Magazine
Yeah, I thought so.
2x on Modern Driveline.
Old 10-10-2012, 11:17 PM
younggun2012
thanks for the info HIO really helpful
Old 10-10-2012, 11:24 PM
85e150's Avatar
85e150
85e150 is offline
A set of headers and a good 4bbl intake and 600 cfm carb will wake up that 352.
Stock, the 400 is a pooch. Lots of potential, as you can see from the links provided. Not cheap--figure $6000 to make that high powered job.
JMO but I would stay with the 352 for now.
Old 10-11-2012, 05:24 PM
younggun2012
i actually though about it for a while i guess i should try to find a 5 speed for the 352 i think it would be the cheaper and easier route especially considering i drive the truck daily from the base and back
Old 10-11-2012, 07:29 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
I only read 22 posts into that swap thread and saw nothing about starter mounting issues. I'd be real surpeised if there aren't some.
Old 10-11-2012, 07:31 PM
willowbilly3
Do you have a link to the info on putting a ZF up to an FE? I'd sure be interested in that swap.
Old 10-11-2012, 09:53 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
There isn't a 5speed to bolt straight to an FE, but a much cheaper alternative is a four speed and different rear gearing. A 360 tends to be pretty happy with 3.55 to 3.73 gears, No matter what you do, though, it's still an FE and will still drink the gas.
Old 10-23-2012, 07:33 PM
younggun2012
i decided to stick with the 352 and find a 4 or 5 speed to put behind it any suggestions on what to go with as far as trans or rear end gearing. I do do alot of highway and interstate driving which is why i am trying to get away from the 3 speed. and also any idea what rearend comes stock in a 68 f100?
towtruck1
01-03-2007 10:46 PM
taxabel
General Automotive Discussion
04-28-2005 10:30 PM
77lowrider
05-27-2003 06:31 PM
82_4x4_swap
09-26-2002 06:50 AM
63unibody
07-23-2001 12:23 PM
Quick Reply: 5 speed for ford 400 long block
