Sponsored by: Real Truck
help
Old Oct 10, 2012 | 06:38 PM
66shadow's Avatar
66shadow
help
I need help in a matter....I have a waste gate that might need replacing...is it something I can do myself or do I need to take it to a mechanic? Also, I want to replace the stock exhaust from the turbo back..what is the stock size and what is a good size to advance up to? I was told that a 4" or 5" would be all that I wanted to go to. I just replaced the stock 373 gears with 410's and the increase response is great...
Old Oct 11, 2012 | 08:31 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
What makes you think something is wrong with the waste gate on the turbo that is on an engine that you didn't mention?
This is a bump anyway.
Old Oct 11, 2012 | 06:00 PM
66shadow's Avatar
66shadow
I don't now how to explain the noise that it sounds like...like a swooshing noise when it opens then closes......hope that helps....
Old Oct 11, 2012 | 08:07 PM
Kdr358's Avatar
Kdr358
Does this help? https://www.ford-trucks.com/forums/1...sed-video.html also as for the gears, if you don't have the special tools for lash adjustments or all the other things just have a shop do it.
Old Oct 12, 2012 | 07:55 AM
miller_feed
First off, you will never hear the wastgate go off. It is in exhaust side of the turbo.
Did you happen to just install the 6637 intake filter?
Old Oct 12, 2012 | 07:03 PM
66shadow's Avatar
66shadow
I have the K&N filter on it..... it came with it...
Hunter2017
6.7L Power Stroke Diesel
27
Jul 24, 2019 02:59 PM
shark1979
Aug 31, 2009 05:21 PM
throwdown
Apr 13, 2009 09:52 PM
crazymut
Mar 29, 2008 06:21 PM
south bay 6.0
Feb 18, 2005 02:31 PM
