Steering wheel offset
Old Oct 10, 2012 | 05:45 PM
trucktech's Avatar
trucktech
I changed my tie rod ends on my 2000 v10 4x4 today. The one at the pitman arm and at the other end connecting to the drag link. I measured everything up before k started and put it back to the same now my steering wheel is off set by about 90 degrees. I am lost now
Old Oct 10, 2012 | 11:44 PM
trucktech's Avatar
trucktech
Any help would greatly be appreciate.
Old Oct 11, 2012 | 03:07 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
When I replaced all the components on the front end of my X, I also had an offset on the steering wheel when I was done. Measured everything and put it all back together the same way it came off. In the end, if you want the steering wheel centered, you will have to take it in and get an alignment. That is what I did. I think the alignment was $70.
Old Oct 11, 2012 | 10:35 AM
timf150's Avatar
timf150
You should be able to adjust the steering wheel center by adjusting the link at the pitman arm.
Have someone inside the truck while you tighten or loosen the coupler on the link at the pitman arm. You will make lots of turns while the steering wheel turns slow.
Or as mentioned above take it in and they will center it for you.
Tim M
Old Oct 11, 2012 | 11:43 AM
EXv10's Avatar
EXv10
Adjust it yourself..........easy
Lovin193
1997 - 2003 F150
Mar 3, 2017 11:42 AM
caminokid863
1997 - 2003 F150
May 9, 2015 09:09 AM
caprisecca
Aug 5, 2012 10:05 PM
cbzdel
Jun 20, 2012 10:24 PM
fn250
Apr 27, 2005 11:57 AM
