High idle after engine swap
Old Oct 10, 2012 | 03:12 PM
cardana24's Avatar
cardana24
Hey Guys,
I have an 01 Expedition with a 4.6L engine. I just finished an engine swap on the truck and now it is idling high, around 1500. Some times it will go out to about 1800 then come back down to 1500. Not sure what's causing this. The throttle cables are not too tight. I used carb cleaner to check for vacuum leaks last night and I could not find anything. Any suggestions? Is this a common problem.
Old Oct 10, 2012 | 04:14 PM
alloro's Avatar
alloro
Is your IAC valve connector plugged in?
Old Oct 10, 2012 | 05:10 PM
cardana24's Avatar
cardana24
yes. To the best of my knowledge everything is plugged in and hooked up as it should be.
nosebreaker
Mar 29, 2011 08:09 PM
unclethumbtack
May 10, 2010 09:08 AM
medtech
Modular V8 (4.6L, 5.4L)
Nov 4, 2005 06:56 PM
oblakmd
Jun 30, 2002 10:31 AM
