P2290
Old Oct 19, 2012 | 12:17 AM
ramsay's Avatar
ramsay
Originally Posted by ramsay
I have also noticed that the charging system is at 14.2-14.5v with spikes up to 14.9. It always used to run around 13.7-14.1v before I started having problems. Could the leak be causing the injectors to draw more power? I have load tested the batteries and they are good.
This new FICM half shell is now burnt internally, although the voltages are back to normal. Could it have been defective? I can't seem to get a straight answer from International on what their warranty is. I've only driven this FICM maybe 100 miles.....I'm starting to think that a Bullet Proof FICM is the way to go.
Old Oct 19, 2012 | 06:42 PM
cheezit's Avatar
cheezit
ford is 12months or 12k miles. no idea on navastar
Old Oct 19, 2012 | 09:22 PM
ramsay's Avatar
ramsay
My local International parts dept doesn't want to do anything for me. I guess I'll have to get a bit more aggressive with them.
Old Oct 22, 2012 | 02:26 PM
ramsay's Avatar
ramsay
I changed injector o-rings, inspected my updated standpipes and dummy plugs and put back together. I am now trying to start and it is spinning easy-hard, easy-hard. (Which is what is was doing before the tear down only when it was hot) Will only crank about 6-7 seconds before the voltage gets down to 10 and so I let off. Both batteries are new this summer. I load tested both of them and they are good. The engine just seems to be requiring a lot of power to turn over. I took out ICP on valve cover and after a lot of cranking oil is trickling out. Shouldn't it be spraying out rather vigorously? I'm wondering if perhaps my HPOP is seizing up or my LPOP is not functioning properly. How much flow should there be from the ICP hole?
Old Oct 24, 2012 | 08:36 PM
amill's Avatar
amill
please post your results after you get this situation figured out.
Old Oct 24, 2012 | 09:24 PM
BLADE35's Avatar
BLADE35
If you want to get anywhere with this You MUST Start Posting Sensor Values
ALOT more to it than VOLTS
Post all these
ICP
ICPV
IPR%
Volt
RPM
CMP/CKP SYNC
FICM SYNC
FICM MP
FICM LP
FICM VP
Post values for^^Each at KOEO and Crank
If you can get it to Start Post same sensors But for Low Idel and High Idel(2500rpm)
Ya it should be shooting out the ICP Hole at say 600-700psi
I didnt read all Posts but Have checked IPR ????? I take it NO since EDGE Wont do it IIRC
To check LPO system Pull OIl Filter Cap and Filter OFF and Hold Drain in Bottom Shut while someone turns over engine the housing should fill fast
To BAD EDGE wont show IPR% thats really important here
If you crank and see batterys hit 10volts but it still cranking Good and FAST KEEP ON IT dont let off your just seeing an ACtual Load test
Old Oct 24, 2012 | 11:07 PM
ramsay's Avatar
ramsay
I'm at a standstill currently. I mentioned the FICM was toast in a prior post and the replacement from International was a piece of crap right from the get go. Although it has a 12 month warranty they are refusing to honour it so I'm trying to decide whether to go with Eds repair or the bulletproof replacement.
I think my batteries being weak this summer (they have since been replaced) must have cooked the first FICM and maybe the starter as it spins pretty fast for a few revolutions then sounds like things are getting tight and the voltage drops off pretty quickly. I have load tested the batteries and they test good but after about 10-15 seconds of cranking they need to be on the charger for a bit before I can crank again so I'm assuming the starter is drawing a lot of power.
So I'm putting a new starter in (under warranty) and a FICM power board. Hopefully my Autoenginuity will be here early next week and I will be able to get to the bottom of this issue.
The origins of this thread were for a P2290 for low oil pressure in the high pressure side. I probably won't get to the bottom of that issue until until I get it running again.
Thanks for the advice......
BTW can someone tell me if HPOPs die a sudden death or is it a slow slide into a non-functioning state?
Old Oct 25, 2012 | 06:00 AM
bismic's Avatar
bismic
I think you have the STC fitting personally (and it is likely to be bad). Also,the Alliance injector kit doesn't come with the dummy plug seals. As far as the starter goies, it sounds more like bad batteries than a bad starter (and the bad batteries and low voltage is what killed the FICM - not the low HPO pressure).
Old Oct 25, 2012 | 10:22 AM
ramsay's Avatar
ramsay
I have replaced the dummy plugs and standpipes with the updated versions.
I have the cast iron HPOP cover so I assume that I have no STC. Engine date is Nov 04
I have load tested the batteries and they test good. Both new as of a few months ago. 12.5 and 12.6 volts at rest and both load test over 850 CCA.
Old Oct 25, 2012 | 12:28 PM
BLADE35's Avatar
BLADE35
your throwing parts at it
you replaced the Power half to the FICM it still shows Good Power According to you so IMO its good What more do you want it to do thats all it does
that FICM wont turn on till it hit Around 600 ICP
since you wont post any values (You and God Only Know whats going on) Buy 1 Of EVERYTHING and Sooner or Later It will STart LOL
Good Luck with it
Old Oct 25, 2012 | 03:09 PM
ramsay's Avatar
ramsay
Good Luck with it
Hey whats with the hostility? The only parts I've "thrown at it" are injector seals because of the P2290 code and a FICM power supply board because of the P611 code. It doesn't show good power. It blew up as soon as I put it on. The stand pipes and plugs were done on one side 20000 miles ago and probably 8000 miles ago on the other when I had the rail off for an injector. The starter sounds like it is possessed and since it is warrantiable whats the harm in replacing it? Where are these parts that I've "thrown at it"?
I can't post values that I don't know. I posted this am that an AE was in the mail. I will post the values when I get them.
Old Oct 25, 2012 | 04:23 PM
BLADE35's Avatar
BLADE35
Oh I thought you had a Gauge Already
Whats the Edge Tunner Only OR ??????
Sorrey about the Bad Mood Just took it wrong with tha gauge thing
How are ypou getting the Volts and FICM Numbers DVM??????
Old Oct 25, 2012 | 04:37 PM
  #28
ramsay's Avatar
ramsay
I have an Edge Evolution which is a tuner and code reader.
I have a digital volt meter on my dash. I don't have FICM numbers. I replaced my power board because of it throwing a 611 code. When I put the replacement in from International my voltage meter went nuts. I took it apart and found that the new board was burnt. My starter has been sounding really weird on hot start and now that I'm trying to prime the system it sounds really weird all the time. Thats why Im considering replacing it.
Sorry about the confusion regarding gauges. I thought my sig had enough info. Maybe I should add more....
Old Oct 25, 2012 | 04:49 PM
  #29
BLADE35's Avatar
BLADE35
You could have a Wire harness issue that Backfeeding power to the FICM and blowing it
is the Little Ground Loop on the FICM Ground to the intake manafold Stud
Old Oct 25, 2012 | 04:56 PM
  #30
ramsay's Avatar
ramsay
Wire is grounded. FICM just started to act up when starter started to sound weird. P2290 has been steadily getting worse but probably unrelated to the starter/FICM issue.
