Unknown shaking
Old Oct 16, 2012 | 01:14 AM
  #31
khadma's Avatar
khadma
Carpenter Local 745
Are you sure itʻs not a Chevy you are driving?
Old Oct 16, 2012 | 06:44 AM
  #32
Diesel_Brad's Avatar
Diesel_Brad
The Bed is NOT The cause of the shake.
Do you feel it in the steering wheel? FRONT
Or do you feet it in the seat? REAR
Old Oct 16, 2012 | 07:47 AM
  #33
minnesotafisherman's Avatar
minnesotafisherman
Rear.. Little in the wheel but I think that's just because it shakes so damn violently I can feel it in the whole cab.
Old Oct 16, 2012 | 07:50 AM
  #34
Diesel_Brad
is everything tight in the rear(u-bolts, spring bolts)
Get a picture of the angle of the driveshaft from the axle.
Have you tried swapping tires front to back to see if the shake follows
Old Oct 16, 2012 | 08:14 AM
  #35
bashby's Avatar
bashby
You can also put the rear on jackstands and see if it shakes. You might be able to see whats out of wack.
Old Oct 16, 2012 | 02:39 PM
  #36
firewood truck's Avatar
firewood truck
Originally Posted by minnesotafisherman
It's more of a "up and down hopping vibration" like you mentioned, FORDF250HDXLT.
That, to me, indicates something is severely out of balance or bent. Can you check you axle shafts at the flange where the studs are? The slightest bend in the flange or axle shaft would shake the whole truck pretty violently.
Old Oct 16, 2012 | 03:37 PM
  #37
minnesotafisherman
Click on the images to check out some video I took today w/ rear axle on stands:
That noise sure doesn't sound good when I hit the brakes. I'm assuming it's because the driveshaft is too short? This has got to be why it is shaking....
Old Oct 16, 2012 | 03:56 PM
  #38
khadma's Avatar
khadma
Carpenter Local 745
I did ask you about the driveshaft about 1000 posts ago.
Is this the same driveshaft that was on before the conversion?
Old Oct 16, 2012 | 04:06 PM
  #39
minnesotafisherman
No, had to get a different rear driveshaft because the 4x4 place around here would not shorten my 2wd aluminium driveshaft. So they made me a new one, 52" from center of u-joint to center of u-joint. Obviously not long enough....
The driveshaft shop guy said I need at least 2 inches of free play if I plan to do any off-roading, etc. That 2 inches of slack must be too much...
Instead of paying about $300~ for a new one, I found one on eBay off a truck with the same configuration as mine, same trans, etc. and it is 1 1/4" longer. So from u-joint to u-joint it's 53 1/4" then the yoke will only be sticking out of the seal 3/4". He only wants a little over $100 w/ shipping.
Unless someone can convince me that the driveshaft isn't the problem..
Old Oct 16, 2012 | 09:11 PM
  #40
Diesel_Brad
By looking at the slip yolk, your driveshaft is TOO SHORT
Old Oct 16, 2012 | 09:20 PM
  #41
Turx's Avatar
Turx
Originally Posted by Diesel_Brad
By looking at the slip yolk, your drive-shaft is TOO SHORT
I agree, but it almost sounds like the dreaded "Death Wobble". Violent cab shaking.....?
Old Oct 16, 2012 | 09:55 PM
  #42
FORDF250HDXLT's Avatar
FORDF250HDXLT
i don't think so,cus iv seen the vids of that happening.that's far beyond a vibration,and there is no way it can be mistaken as to if it's the front or rear.
that there shakes the steering wheel very violently and it looks extremely unsafe.if that was going on,he'd know it.
http://youtu.be/PSDBCV-gcs8
Old Oct 17, 2012 | 01:54 AM
  #43
minnesotafisherman
Haha no way I do not have the death wobble. It is an annoying shake, but not nearly as bad as the above video.
Brad do you think if I got the 53 1/4" driveshaft that it would resolve the issue? There would only be 3/4" of the yoke sticking out past the tailshaft seal.
Old Oct 17, 2012 | 07:28 AM
  #44
Diesel_Brad
One, that guy who continued to drive with that death wobble is a TOOL.
Two, Minnesota how much of the yolk goes into the transfer case? If you dod not have enough in there, there will be no support and the shaft will slop around and cause a vibration
Old Oct 17, 2012 | 12:31 PM
  #45
minnesotafisherman
I am not sure how long the slip yoke on the front driveshaft is. It's the same yoke off my old 2wd driveshaft, had the shop switch it over to the new one. Can't pull the driveshaft to measure the yoke right now since the truck isn't here, but I would say 5-6 inches?
So there is probably only 3-4 inches in the back of the transfer case.
I think I'm just going to order this "new" driveshaft, swap it in there, and see if it solves the problem.
