Here's the deal
About a mounth ago, I decided to restore my dads 1949 f1 panel truck without him knowing and then give it to him as a christmas present. Biggest problem is it has not run since the 70s. Oil was all slugged up so I was told to drain it and put disel in it to break up the slugg. It worked. Now the problem is I had it completly drain and I went to put oil in it and after 3 quarts, the dip stick was at the full mark. It is a flathead 6 so I was told it should take 4.5 to 5 quarts. Any ideas??
Thanks
Nick
It is possible that you have some sludge backing things up a little. You should crank the engine through a few revolutions and re-check the oil. Did you get a lot of goo out with the diesel??
I turned the enginge over by hand a few times and the dip stick read the same. And yes I did get a little goo out with the dissel.
With a bypass filter, there's no benefit to filling the canister, it will just drain to the oil pan.
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
I was able to get the oil pan out and you guys were right, the bottom was covered in slugg. Clean it all out and here is the next question... Will this stuff, Permatex/3 oz. tube Form-A-Gasket no. 2 sealant (80016) | Gasket Sealant | AutoZone.com_, work as the gasket for the oil pan? It says it will but I'm not sure. The other question is it says that it resists Gasoline, Oil, Kerosene ....... So will this work for my carborator because I took it apart the other day and reliezed there are no gaskets for it.
Nick
Nick
EDIT: Dennis Carpenter has the oil pan gasket set for $20
I wouldn't use anything on the carburetor but a gasket set. There are too many little holes that wouldn't like even a small drop of that stuff to get in them. It would be too easy to ruin the carb.
