I just got ahold of the coveted D60 its had a good run through and is ready for install, the only issue is what kind of front springs would be good for 35" tires. i want to keep towing in mind and want the truck to fill out the wheel wells nicely, no block lifts!!!! the axle has 4.11's and i have a 10.25 with 4.11's also im swapping in. also can the stock track bar be used with different springs or is there a adjustable bar out there?
