Front Bumper Question
Old Oct 9, 2012 | 05:56 PM
jeffreyt's Avatar
jeffreyt
I had a wire harness with a connector for each fog light. Didn't have to run any wires to the switch, they were already there... I cut the factory plug off, crimped a splice, and heat shrinked over that. You may have the harness there already, just plug and play.
Old Oct 9, 2012 | 06:15 PM
pin8246's Avatar
pin8246
I cant find any wires anywhere that would be for the fog lights. Im thinking mine didnt come with them.
Old Oct 9, 2012 | 06:21 PM
BigAlsPSD's Avatar
BigAlsPSD
What year is your truck? IIRC foglights weren't available til 2001 or 02.
Old Oct 9, 2012 | 06:32 PM
jeffreyt's Avatar
jeffreyt
guess not, they should be easy to find. Mine have a zip tie to the block warmer plug...
Old Oct 9, 2012 | 06:34 PM
pin8246's Avatar
pin8246
I didnt think mine did. Mine a 00. Guess Ill have to wire them up to work then. So much for the easy way.
Old Oct 9, 2012 | 06:35 PM
BigAlsPSD's Avatar
BigAlsPSD
My 2000 doesn't have provisions for factory fog lamps.
Old Oct 9, 2012 | 06:38 PM
pin8246's Avatar
pin8246
Yea im almost positive mine doesnt either. Ill go with I think his names Joe's route and wire them up to a toggle. Still trying to learn peoples name by there screen names.
Old Oct 9, 2012 | 08:10 PM
CSIPSD's Avatar
CSIPSD
My name is in my sig... Everyone should do that.
The Fogs were not avalable until 2001. My wifes 2001 Excursion did not come with them.
You could even go with a HID set up since your needing the bulbs, harness and such... Just an idea. I am NO fan of HID's but its an option.
Old Oct 10, 2012 | 02:22 PM
pin8246's Avatar
pin8246
Joe you seem to know your stuff on here, and you brought up the HID suggestion. No experience with HID except for the stock ones in my Toyota so adding them is something new. Since they are going to be on the fog lights, and run off of a toggle switch, can I use one of the 30-50 dollar kits im seeing off of Ebay? What im seeing there looks like it has the bulb and mounts into the casing, and I wont need to buy any of the stock parts from Ford, is this right? And im looking for the 9005 setup right?
Old Oct 10, 2012 | 02:34 PM
CSIPSD's Avatar
CSIPSD
Thats what I am thinking... Most of the HID kits out there use the factory wires as nothing more then a trigger.
Since you dont have the factory wires all you will need is a Key on power and a switch.
Old Oct 10, 2012 | 02:35 PM
pin8246's Avatar
pin8246
Thats what its looking like. And you said your using the 9005 bulbs?
Old Oct 10, 2012 | 02:47 PM
CSIPSD's Avatar
CSIPSD
Thats what I use in my fog lights, the factory fog lights use a different bulb (cant recall the number) but there only 45w. The 9005 are 65w...
With the HID's you could more then likely just go with what ever factory bulb it calls for.
Old Oct 22, 2012 | 05:51 PM
  #28
pin8246's Avatar
pin8246
Well my fog lights are now 9005 bulb, with the 6000k color. Hasnt been night yet, but just shutting my shop door you could tell how bright they were. Ended up going with a kit off of ebay, and seems to work. The company sent 9006 bulbs to start, but quickly sent replacements after I told them. Since it is a 00, I had to wire it up. These are all plug and play systems, so I went ahead and got the pigtails from the local parts store so I didnt have to cut the ballast wires.
First I tried to wire it into my light switch, basically taking the power from the parking lights, to power the toggle switch, so those would have to be on to power the toggle. That was a no go. Had it all wired, tried it out, and the lights just flickered, causing the radio to do the same.
So I basically hard wired it. Got the constant power from under the dash, spliced into that so I didnt have to run from my battery, ran to the fuse, (tried a relay but couldnt figure it out), to the toggle, then out. All wire I took and twisted together with a drill to keep together (not tight) the heat shrinked it all. So what little wire you can see under the hood is black.
All in all, very simple, and we will see what the light output looks like tonight.
Thanks for all the info.
PAf250
Jun 20, 2017 03:14 PM
Jleas524
1997 - 2003 F150
May 14, 2015 07:43 AM
blsaoo86
1997 - 2003 F150
Nov 10, 2014 03:53 PM
sjrank
Aug 21, 2009 11:38 AM
orangebanzai
2004 - 2008 F150
Jul 9, 2004 06:26 PM
