engine shut down
Old Oct 8, 2012 | 02:39 PM
bobreynolds's Avatar
bobreynolds
engine shut down
Hello, new to the diesel forum. Was driving my 2002 excursion 7.3 yesterday and it just shut down. Will crank over but not start. the coil light comes on but will not go off. I am thinking maybe a crankshaft position sensor of fuel pump. Could someone give me a hint where i might find the sensor.
Thanks, Bob
Old Oct 8, 2012 | 02:54 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
Hi Bob, Welcome to our gang. Sounds like a cps. Its located to the left of the crank pulley, 10mm bolt as I remember. Pretty easy to change. Just clean the area before removing. Unplug the wires and gently pull out. Replace with a ford or IH part. Lube the o-ring and reinstall. A lot of us put some dielectric grease on the plug. Whats a coil lite? Is the oil full?
Old Oct 8, 2012 | 02:55 PM
fordpride's Avatar
fordpride
Coil light ?
Does the tac move when cranking ?
Do you have a wait to start light ?
Can you hear the fuel pump ?
Did it die like you turn off the key or like it ran out if fuel ??
Old Oct 8, 2012 | 02:58 PM
CSIPSD's Avatar
CSIPSD
Coil light would be the WTS light on a 2002 or newer truck...
CPS is more then likely it, however it could be an IPR...
CPS is cheap and easy.
Old Oct 8, 2012 | 03:10 PM
bobreynolds
Thanks for the quick response. I guess what i call a coil light is a wait to start light or glow plug light. It died while running. but not like running out of gas, just stoped running. No stalling or spuddering.
Old Oct 8, 2012 | 03:13 PM
fordpride's Avatar
fordpride
I'd put a Gord or IH CPS in it and go from there. If that doesn't work then you'll have a spare which you need to have anyway.
Old Oct 8, 2012 | 03:28 PM
bobreynolds
thanks again. I am having a little problem locating the sensor. so far i got front left side by crank pully. Is there wires coming from it and is it easy to spot?
Old Oct 8, 2012 | 03:43 PM
stinson 108-1
stinson 108-1
Left/passenger side. You'll probably see it easier from under the truck. Yes, it has wires.
Old Oct 8, 2012 | 03:48 PM
bobreynolds
found it and have it in hand. thanks agian. you guys are awesome.
Old Oct 8, 2012 | 04:11 PM
fordpride's Avatar
fordpride
It's at 11 o'clock of the crank pulley
Old Oct 8, 2012 | 04:29 PM
stinson 108-1
stinson 108-1
Bob, Don't forget to post back with the out come!
Old Oct 8, 2012 | 04:35 PM
stinson 108-1
stinson 108-1
Hey Mike, Ford Pride, I saw that quote under your sig. on a Canadian billboard, next to " KY, we can't think of any other use for it either". haha.
Old Oct 8, 2012 | 04:44 PM
fordpride's Avatar
fordpride
Hahahaha lol
Highmark18
Nov 8, 2012 05:24 AM
02GrayPowerStroke
41
Jan 14, 2008 07:28 PM
toreed47
25
Jun 12, 2007 12:26 PM
belas
Nov 4, 2006 11:41 AM
Red Boat
Jan 28, 2005 09:59 AM
