I.C.P
Old Oct 8, 2012 | 12:34 PM
101stcowboy's Avatar
101stcowboy
I.C.P
Ok this what I have happening, I have a 94 f-250 7.3l power stroke
I having a check en light and the truck will run for 30 then it shuts off, so I found out that if I unplug the icp Im able to drive the truck with no problem, now I did pluged it back in and I forgot to unplug it for weeks it drove fine noproblem and no light, then I got another check light and again I unpluged it drives fine. what should I do? I need to fix it cuz Iam going hunting next month. Iam thinking about replaceing the oil pump the ipr ,icp. any ideas? it makes it bad cus I have to drive from northern Colorado to southern Colorado to Ft Carson.
Thanks
Sgt.Walker
Old Oct 8, 2012 | 12:49 PM
DIYMechanic's Avatar
DIYMechanic
Sounds to me like you need a new ICP. It is either that or the IPR (unplugging the ICP can occasionally un-stick a stuck IPR) but since it runs fine with the ICP unplugged I think your IPR is okay and you just need a new ICP.
Does it (the ICP) seep oil? That's a sure sign that it is shot.
And Thank you for your service to our country!
Old Oct 8, 2012 | 02:39 PM
Talyn's Avatar
Talyn
Just stay away from the Fleabay ICP's.
They are for a different truck and wont work.
Just order it from clay and be done with it. =)
Old Oct 8, 2012 | 02:51 PM
101stcowboy
ok ill just go to Ford and get it I cant afford alot Im up for any sugg maybe post some links
thanks
Old Oct 8, 2012 | 02:55 PM
DIYMechanic
It isn't cheap, but I bet this one is cheaper than you will get it from Ford.
Riffraff Diesel: Motorcraft ICP Sensor 94-96
Old Oct 8, 2012 | 03:25 PM
101stcowboy
kool thank's guys Iam really greatful for your help..
thanks
Eagleye2002
Jun 14, 2013 04:31 PM
Ctkallday666
18
Apr 26, 2011 01:25 PM
jrobs86
Mar 10, 2011 03:06 PM
427 fordman
26
Mar 10, 2010 03:34 PM
redneckmechnic
Dec 6, 2003 10:28 PM
