Honestly I never joined up over here because everytime I tried to open the forums my computer would close down the internet haha but, in the last few months its been working so I've been lurking around and learned some stuff... I figure it was my time to join.
This truck has come along way, thanks for adding your build link to the page, between the 2 builds the truck is pretty well documented from when you pulled it out of the field up untill now.
Hey monster67 i'm glad you joined I just joined myself and i'm practically doing the same project! I was wondering How far back you moved the rear cab mounts and if the front gas tank was in the way?
Man, your truck has come a long way. I read your thread over on Pirate and it was very interesting to see your progress and what you have done to it. Keep it up and good luck getting your engine going, if you haven't already done so.
I had to use the rear cab mounts off the Supercab frame. The regular cab mounts are inside the frame and wont work, Supercab mounts are outside the frame. I don't remeber exactly how far back they are, the easiest way that a could find to do it was to:
Put the cab up on the frame
Get the front cab mounts bolted down
Put the front clip back on and bolted down
Bolt the rear cab mounts to the cab
Use a floor jack to raise/lower the rear of the cab until everything looks right
Measure
Measure
Measure again
and thats were they go
You will need a 1/2" plate on each side to shim the rear mounts out and atleast a 2" body lift.
My truck doesn't have the front gas tank, it got removed long ago, but I cant see why it would be in the way
Any questions you have, feel free to ask or if you need pictures of anything let me know and I'll do what I can
Thank you , it really has come along way, I'm very happy with how its turning out. The whole motor thing sucks, but it will get worked out, i just want to drive the damn truck, between the cab swap and the motor its been down for a year now!
