turbo question
Old Oct 6, 2012 | 06:19 PM
Liquid10Rider's Avatar
Liquid10Rider
turbo question
Hey guys I have wanted to possibly swap out my turbo for a better one but not sure if I should. My truck is an 01 with 119k on it. Is there usually a time frame that the turbo should be replaced before something happens? And what is normal boost pressure? I run if I romp on it about 10 psi and no higher.
I have to take the turbo out anyway to reseal the pedistal so i figured if I was going to take it out should i just replace it?
-AJ
Old Oct 6, 2012 | 06:43 PM
MikeSDK's Avatar
MikeSDK
You should pull more than 10 stock. More like 17-18. Sounds like a boost leak. Have you checked your boots?
Old Oct 6, 2012 | 06:54 PM
Liquid10Rider
I have changed then about 6 months ago with RR boots and clamps
Old Oct 6, 2012 | 07:31 PM
BadDogKuzz's Avatar
BadDogKuzz
Then I would think it is your up pipes are leaking if you are only getting 10psi of boost. Or a weak wastegate actuator. And if you have money to spend then go with the 38r.
Old Oct 7, 2012 | 05:42 AM
Liquid10Rider
If you had s boost leak would you hear it? And are there any ways to tell if you have a leak besides the gauge?
-AJ
Old Oct 7, 2012 | 08:57 AM
Christof13T's Avatar
Christof13T
Put together a boost leak detector... very easy and cheap... and an invaluable tool.
For up pipes... just look for soot where the up pipes meet up with the collector.
You may also have a bad compressor housing oring...
Look for bolts backing out of the center cartridge that hold the turbine housing on.
Your making boost... so the turbo is functioning... but there is a leak somewhere.
My bet is leaky up pipes.
Xtof
Old Oct 7, 2012 | 10:28 AM
timmyboy76's Avatar
timmyboy76
AJ, i'm seeing the same #'s as you. I did the 10k mod, and noticed that i can then, spool up and hit 22psi . I'm thinking my problem may lie with a bad ICP, but i dont have the software to tell me otherwise.
Old Oct 7, 2012 | 12:07 PM
Liquid10Rider
What is normal icp press
Old Oct 7, 2012 | 03:47 PM
1fixitman's Avatar
1fixitman
Clean your ebp sensor tube and the port feeding it also.
Old Oct 7, 2012 | 04:38 PM
Liquid10Rider
Hey guys today i really got on it and found I'm pushing nearly 14psi also i looked at the up pipes and the both have soot marks on them. When i do replace my up pipes I'm going to buy them from RR but what else should be done at this time so i don't have to r&r the turbo twice? And its it fairly easy to rebuild the ebpv?
-AJ
Old Oct 7, 2012 | 05:48 PM
JohnDeereFarmerUSMC's Avatar
JohnDeereFarmerUSMC
Do you need the ebpv? I and many others have just deleted mine (you can go 2 ways, cheap and do the work and plug the hole yourself, or buy an ebpv delete pedestal and housing). The rebuild itself doesnt look too hard to do on them, there are quite a few write-ups and even videos on it.
Old Oct 7, 2012 | 06:08 PM
Liquid10Rider
Now being in Jersey we don't see extremely low temps but it does get cold here. Would deleting it have an effect on cold weather starts?
Old Oct 7, 2012 | 10:46 PM
guitarpicr's Avatar
guitarpicr
Shouldnt effect starting but it wont heat up as fast & you wont have the airplane sound out the exhaust.
Old Oct 8, 2012 | 04:34 AM
Liquid10Rider
Sorry about that i worded it wrong. I needn't to say after start up. I'll just stick with rebuilding it and replace the up pipes. thank you guys for all the help!
-AJ
messeswithtrux
17
Jan 5, 2020 02:59 PM
mikec91
Feb 4, 2013 08:26 PM
dyoung14
Nov 24, 2009 06:46 AM
Jakeman68
13
Jan 1, 2007 04:22 PM
ram2miller
Jun 29, 2006 11:01 AM
