I was changing my oil today on my '03 F250 6.0. and was also replacing my dipstick since it was barely together the last time I changed the oil. I finished up the oil change and inserted the new dipstick. When I pulled the dipstick out to look at the level it was missing about 1/2 of the tip that shows your oil level!!!!!
Is this something that will fall harmlessly to the bottom of the oil pan and sit there?
If not then what can/should be done to get the piece that broke off out?
Please keep in mind that I am not looking to get a new engine or anything crazy out of this. I have contacted the companies involved and they were both very helpful but with this being Saturday I will need to call back on Monday. I am hoping to get some good knowledge form here before the call on Monday.
I believe you will be able to remove the tube that the dipstick resides in. That should reveal the bottom lost section. I can't tell you exactly everything that might need to be removed (if anything) to get access to that tube but I believe that's your way out of this problem.
Thanks for the quick reply.
I was wondering if that might be the answer while I was standing staring helplessly at the engine in my driveway earlier. I do not have a good manual for it yet so I might have to go get one.
So I just reread your original post and I missed the 'tip' part. I thought somehow 1/2 the length of the dipstick had broken off.
The tip, well that little bit I don't know if removing the tube will help now that I think of it. Perhaps it'll end up in the oil pan and either come out with an oil change, or stay there and never be an issue because of the screen on the oil pickup?
How the heck does a chunk just fall off a brand new dip-stick? Was it OEM or an aftermarket jobber part?
It was an aftermarket part from one of the "big boys" in the parts world. I saw so many complaints about the stock dipstick tops breaking like mine did that I figured that OEM might not be the best option here.
That is what I was thinking / hoping would be the case. That is one of the reasons oil pumps have the screens on them. I help a buddy that races sprint cars on his engines from time to time and have seen some odd stuff in the oil pans before. If the broken portion does just fall down to the oil pan I think I will be OK.
I think it shouldn't be an issue. As the OP stated, there's a screen on your pickup that should keep anything large from being recycled thru the oil system.
Mike
If you are worried about it you can do this.
You should also pull the tube in hopes that
some how it got stuck in the end. but that
would be just too easy.
Get a clean bucket and drain the oil into a funnel
with a screen and see if it comes out. If not you can
then use a flashlight with a fiber optic cable on it Fiber Optic Light (Model-A.org)
and slide that into the the drain hole and have a look
if you see it you reach in with the a small flexible
grab tool and snag it. Most likely it lost the plastic
end when you pulled the stick up the tube and it
got stuck on the end of the tube in the pan. I am
not sure on this part but I think that the tube goes
below the windage tray in the pan. For the ones that
ask "What is a windage tray." It helps keep the oil in the
pan from sloshing up onto the rod ends as you drive and
aerating the oil.
One other way to fish it out would be a length of
uncoated welding filler rod with a hook bent into the end
then insert into the drain hole and sweep the bottom of
the oil pan bringing it back to the drain each time.
Being a plastic part all the above may be un-needed
and it may just come out with the flow of the oil draining.
It sounds like I am going to be OK on this. If appreciate all the advice and answers to my question.
Please keep the advice coming.
Now that I know the engine should be fine since the broken piece will just fall into the oil pan what do you think the manufacturer should / would be willing to do to make it right?
Well, if the truck, the parts and the service is all warrantied (assuming they did the work and supplied the defective parts)...... they should be taking that pan off or fishing that piece out of there somehow to make it right. I would want to "see" that piece as well.... not just take their word that they got it out. t sucks that they have to do it but at the end of the day..... did you "ask" them to put a liability into your pricey engine?
Folks are always griping about the cost of a mechanic at the dealership and why they charge so much.... well it's because you come to expect better when things like this happen! They should look after you.
I have a couple of follow up questions if dropping the oil pan is the ultimate solution for me.
Is that something that can be done with the motor still I the truck? Or is it more involved?
What would be a reasonable estimate to have an experienced shop do that?
And finally if it is a more involved process what else should be looked at or done while its apart? The truck is bassically stock with 93000 miles on it so I would be willing to spend a few extra bucks if it was already getting some work done on it.
Here is a picture showing exactly what the problem is:
is that a plastic or metal tip?
if it's plastic, don't worry about it.
if it's a metal tip, and it isn't in the tube, which it's not likely to be, then it's down under the windage pan most likely.
here's how i'd get it out.... drain the oil thru a funnel with a screen, and
see if you get lucky. i give it a 25% chance.
after that doesn't work, get one of these...
if the tip is magnetic... i don't think they are
i think they are zinc or a pot metal alloy.
get a spherical one. a flat one you might not be able to get
it off a flat metal surface. that will allow you to snag it and
roll it over to the drain hole.
about those magnets......
the really big ones are dangerous. you get it between your
hand and some steel, and it can mash and amputate a
finger.
