Sponsored by: Real Truck
Integrated Brake Controller
Old Oct 5, 2012 | 06:11 PM
cusneddie's Avatar
cusneddie
2006 F250 - no power to the truck plug-ins, OEM bumper plug or bed plug-in to operate trailer brakes. Marker lights, brake lights, and flashers work (individual and 4-way), no trailer brakes....trailer brakes work when the controller lever is operated. Any ideas out there? Had the truck checked to see if computer and controller are communicating...all is well. Just no power from the brake pedal to the connectors. Appreciate any help.
Old Oct 5, 2012 | 08:19 PM
mikeismadness's Avatar
mikeismadness
Sounds like a bad ground/electrical problem somewhere.
Old Oct 5, 2012 | 08:32 PM
cusneddie's Avatar
cusneddie
Appreciate the suggestion. Have read other posts (not the same issue) that the brake pin could be squeezed together and not making contact with the plug side and also corrosion could be an issue. Not so sure on that because neither plug mounted on the truck works. Will check both in the A.M. though.
Old Oct 20, 2012 | 08:08 PM
cusneddie's Avatar
cusneddie
Solve the problem! Installed a Tekonsha P-3 brake controller. Pretty easy install with the wire harness and connector that's made to match the Ford harness and connector. Thanks e-trailer.com for all the assistance!
carolinaborn82
2009 - 2014 F150
May 25, 2017 05:26 PM
1duallyman
Electrical Systems/Wiring
Jun 9, 2011 05:49 AM
lud04X
All Things Towing
13
Mar 23, 2008 07:57 AM
oppy
All Things Towing
16
May 18, 2004 10:49 AM
Jesters Court
All Things Towing
Oct 30, 2003 10:27 PM
