6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Cleaning exhaust filter
Old Oct 5, 2012 | 01:03 PM
Kyle799's Avatar
Kyle799
I get this message constantly during the regen stuff, which means i dont have the latest flash right? Do i need to get this?
Should I finish the clean every time? This is a daily thing if i dont... i usualy drive about 10 miles to an from school every day, mostly on highway, and then county roads
Old Oct 5, 2012 | 06:27 PM
galaxie641's Avatar
galaxie641
10 miles isn't enough to clean it, you are wasting a lot of fuel doing it every day and the truck should not be shut down during a regen. Best thing is to get rid of it and never worry about it again.
Old Oct 5, 2012 | 09:11 PM
StanleyZ's Avatar
StanleyZ
man, that's a lousy school car. You are using the truck the worst possible way you can. And spending about as much money as possible on a 10 mile trip to school. Short trips just kill this truck. What to do:
1. What the guy above just said "delete the dpf and tune the truck" very expensive and very effective. But against the law.
2. Figure out a way to drive it more distance. What's happening to you is it's trying to clean but never gets done. That's also why the message stays on. I'm kinda suprised you are not getting a "DRIVE TO CLEAN" message. Even if you have the latest flash the message will stay on if you don't let if finish cleaning for a couple trys.
3. Trade vehicles with someone who drives a lot on the highway pulling a heavy load. That's what these trucks are for and what they do best.
Seriously dude, you're killing the truck and probably in for some very high dollar repairs if you continue. hope this helps.
Old Oct 6, 2012 | 08:02 AM
Gearitis's Avatar
Gearitis
Get it out on the Hiway and warm it up and let it finish a good regen. I drive 16 miles one way to work and it is mostly Interstate. I do pull a 5er every couple of weeks hard so I work the truck a bit. I also live in Texas and the ambient temp starts out higher than you. Usually mine will start regen about 3 miles after I start it, then it will regen about 1 mile before I get to work. That gives me a mile or so of cooloing which brings it back to about 575 at the parking lot. I usually idle for about a minute and then turn it off. If it has not finished before I am ready to park, I know that it has gone thru the majority of the regen (90%) and not to concerned but I still high idle till it cools down. Not allowing it to cool properly can crack the DPF. Do you have the oppritunity to get it out on the hiway, where you live? I know some of Colorado is very rural and no place to really put it down and get it hot.
Old Oct 6, 2012 | 08:24 AM
wp6529's Avatar
wp6529
My standard recommendations including the latest flash, regen, etc.:
If you have not owned one of the newer emissions controlled diesels previously (any brand), be aware that they are far more dependent on proper maintenance than earlier diesels.
Key 6.4 maintenance items:
* Oil changes every 5,000 miles, with quality oil (synthetic recommended), used oil analysis (Blackstone) for every change. Use only Motorcraft oil filters or the Racor (OEM) equivalent.
* Fuel filter changes every 10,000 miles. Use only Motorcraft FD4617 or the Racor (OEM) equivalent filters.
* Coolant nitrite testing at least every 15,000 miles. I recommend every 5,000 miles at the same time you do the oil change for simplicity, the test strips are inexpensive. Do not be confused by the test directions warning not to sample from an overflow tank, the 6.4 does not have an overflow tank it has a degas bottle. The degas bottle is part of the coolant loop with constant circulation so it is a valid testing point. I do not bother "taking a sample", I simply clip the test strip on the end of a long hemostat and dunk it in the degas bottle to test. If the test is below 800ppm and above 300ppm add two bottles of VC-8 additive. If below 300ppm the entire coolant system must be flushed with VC-9 cleaner, rinsed well and refilled with new coolant.
* Cooling system flush with VC-9 and refill with Ford Gold coolant every 60,000 miles, sooner if you have neglected testing and the nitrite is under 300ppm.
* Use a quality fuel conditioner such as the Ford PM-22a/23a conditioners at every fueling. They add lubricity to the fuel, something that ULSD is lacking in which helps protect the high pressure (up to 26,000 PSI) fuel pump. They also help to reduce soot production which results in less frequent DPF regens and less fuel dilution in the engine oil.
* Drain the HFCM water separator monthly. The fuel drained can be poured back into the tank carefully leaving behind any water at the bottom of the collection jar (normally very little). If the water separator drain does not flow well or at all, it may be clogged with either parafin blobs or with bacterial growth. In either case at a minimum the drain valve cover needs to be removed and the clog cleared. If the clog is significant the HFCM cover needs to be removed for full cleaning. If the clog is white and waxy it's parafin and not a significant issue. If the clog is brown or similar and more slimy it is bacterial growth and the fuel tank should be "shocked" with a biocide such as Power Service Bio-Kleen which should not be confused with their Diesel-Kleen.
* The truck should not be used for all short trips and stop and go traffic. The 6.4 and other emissions controlled diesels need regular longer periods at highway speeds to allow proper DPF regeneration and to get to proper operating temperature to help reduce fuel contamination in the engine oil.
* The latest PCM flash (11B23) does not provide continuous indication of when a DPF regen is taking place, it does however add much improved engine monitoring for developing issues. Over time you will get to recognize the subtle changes, but I recommend adding something like the ScanGauge II which will allow you to monitor the DPF temperature which is a clear indication that a regen is in progress when over ~600F.
* Avoid shutting the truck down with a regen in progress. If you have to, run the engine at high idle for a few minutes in park before shutting down to allow the turbos to cool down to normal temperatures before shutdown. If you are interrupting the regens you will see it in your Blackstone report, otherwise you should see very little fuel dilution, <1%.
You should also absolutely get the Ford ESP extended warranty, any repairs to the 6.4 are expensive and a single big repair can easily cover the cost of the ESP warranty. The coolant nitrite testing that many people overlook *is* in the owner's manual diesel supplement, so if you neglect it Ford can deny warranty coverage for resulting damage.
Other Super Duty maintenance items:
* Change transfer case fluid every 60,000 miles.
* Change rear differential fluid every 50,000 miles on DANA axles (F350 DRW and up).
* Change transmission fluid and filter every 60,000 miles on Torqshift transmissions (100k on manual transmissions). If you have the early Torqshift with the external filter the interval is much shorter.
Resources:
Coolant test strips - Buy the 4pk, not the bottle of 50, the strips have expiration dates and you'll only need <10 per year. Most dealer parts counters should have the test strips, NAPA has them, or order direct from Acustrip.
http://acustrip.com/CTS-3_Retail_Order_Form.pdf
Used oil testing - Blackstone Labs, get the pre-paid 6pk of test kits to save a few bucks. You don't need the TBN option:
Order Now
Ford ESP extended warrantys - You can buy them online from real dealers, or use the online price from a real dealer to negotiate a better price from your local dealer. You absolutely want the ESP, while the 6.4 is not problematic as some claim as long as you maintain it properly, nearly any repair is big $ and one good one will cover the ESP cost:
Ford Extended Warranty - Genuine Ford ESP
DPF, oil, coolant temp monitoring - ScangaugeII, you will need to program the X-gauge commands for the 6.4:
ScanGauge - Trip Computer + Digitial Gauges + ScanTools
Ford Specific XGauges : Linear Logic : Home of the ScanGauge
ZuluFoxtrot
Jan 27, 2018 07:10 PM
nathan_2017
Dec 24, 2016 08:23 AM
Ricohman
6.7L Power Stroke Diesel
Jun 8, 2015 07:38 PM
Amelio
16
May 9, 2014 05:41 PM
Byram
Oct 30, 2013 07:02 PM
