Maybe not vacuum leak?
Old Oct 4, 2012 | 11:14 PM
69 F100 Cali's Avatar
69 F100 Cali
I posted about a vacuum leak from my brakes recently before really dealing with it much. I recently looked into it and realized that it only rev up with it slightly depressed no brake and full brake don't rev it. Also I sprayed the hose and it didn't rev so I think it's a power booster issue. The problem is I don't know how cheap and or how to repair a power booster.
Old Oct 4, 2012 | 11:47 PM
willowbilly3's Avatar
willowbilly3
It's hard to figure out what you are trying to say about the revving up part, the sentence makes no sense. You can't service the booster yourself, only the hose and check valve, otherwise replace it.
Old Oct 5, 2012 | 12:35 AM
69 F100 Cali
Ok sorry with the brake pedal untouched and with it pushed to the floor (seperate positions) there is no leak and no change in rpms. With the brake depressed slightly like in a normal stop the rpms increase a few hundred or so.
Old Oct 5, 2012 | 06:21 AM
jim collins's Avatar
jim collins
Boosters had it,has an internal leak , time to replace.
CWR032
Oct 30, 2017 12:30 PM
Mudd460
May 13, 2009 08:33 PM
78 Ranger
Aug 3, 2005 11:26 PM
MatthewC
1978 - 1996 Big Bronco
Jul 30, 2004 09:07 PM
myke
1997 - 2003 F150
May 3, 2003 09:25 AM
