Help Me Please
Old Oct 10, 2012 | 09:45 PM
  #61
Gary Lewis's Avatar
Gary Lewis
Ok, LMC. Dad's truck has the same type of trim but it is aluminum and some of it is bent. So, I'll either have to find replacements or go with what you have.
Good job on the choke. You sure learn quickly!
Old Oct 10, 2012 | 09:49 PM
  #62
truckertrav's Avatar
truckertrav
Teaching an old dog new tricks. I'm proof of that...
I have one piece of the aluminum trim gone, Left rear.
I was looking at the stainless from LMC...
What pieces are bent on your truck, Gary..
Old Oct 10, 2012 | 09:56 PM
  #63
Gary Lewis's Avatar
Gary Lewis
I'll have to check, but I know the passenger's side rear one is obliterated - along with the bed. I'm thinking the driver's side front is bent as well. I'll look tomorrow to confirm, but it is the stuff right on the wheel opening.
That stainless looks good on Demeron's truck, but I'm not sure whether the shiny stainless or the aluminum trim would be best on Dad's truck. And, another problem I have is the upper trim - it is the stuff with a rubber strip in it. Haven't seen replacements for it.
Old Oct 10, 2012 | 10:15 PM
  #64
truckertrav
No score on the upper trim either..Mine just glued on...Not going back after paint..
The pieces of the wheel well trim I took off are all good. The left rear is the only one missing..
I am going with the stainless as I have chrome wheel.
I think yours would look good with the aluminum trim because you have the aluminum wheels....
Old Oct 11, 2012 | 09:42 AM
  #65
Gary Lewis's Avatar
Gary Lewis
As it turns out, the one you have missing is the best one of mine and all the others have some damage. Sent you a PM.
Old Oct 11, 2012 | 01:39 PM
  #66
81-F-150-Explorer's Avatar
81-F-150-Explorer
A word of advise on those wheellip mouldings.
I had a guy run into the back end of me and damage one of those mouldings. Went and bought a NOS one from the dealer. When it arrived it was turned into a pretzel and in worse shape than the original. The package was insured so got another one, same thing happened. It took three packages to get me one without damage to it. When you are talking about New Old Stock parts, it is a crime to have them damaged in shipping, when less than 6 NOS pieces survive in the world.
My advise would be to package them in a large crush resistant box with reinforcement cardboard inside for extra protection and mark fragile on the box.
Would hate to see them turned into "pretzels", etc...
As for the 1980-1984 upper metal mouldings with vinyl trim, I have seen those in the yards recently, what sections do you need? I'll see what I can find.
Old Oct 11, 2012 | 01:57 PM
  #67
Gary Lewis's Avatar
Gary Lewis
Sorry for hijacking this thread, but I would like to answer this. First, the short answer is that I need essentially every piece of the upper molding since the rubber has either shrunk or come loose on the ends and been trimmed. In other words, none of the rubber is good, but then you might not be able to find pieces with good rubber either so maybe I can find replacement rubber pieces, probably in a roll of self-adhesive trim.
Assuming I can find the rubber, the one piece I for sure need is the little piece on the cab behind the driver's door. However, the piece on the bed on the passenger's side has a small ding and it may be slightly bent from the accident where the bed was crushed.
As for the shipping, I whole-heartedly concur that it will need to be well boxed/protected.
Old Oct 26, 2012 | 12:55 AM
  #68
RockWVU's Avatar
RockWVU
Kinda on the same path as the original poster....
When going to a mechanical pump from a dual electric 460 on my 86 f350, does the return just get plugged with a bolt? or should i keep it hooked up via the metal fuel line junction (for lack of better words)? I think this junction allowed vapors back thru to prevent vapor lock.
P.O. installed mech fuel pump due to common failure of electrics towing. I am not sure if he removed all the electrics from the tank but the oil pressure switch is disconnected (so they wouldnt be pumping) and i am placing a oil press gauge where the switch is.
So i guess i am asking in short.... Should i hook up the return using the old metal junction/line? or should i go with a new single fuel line from the mech pump to carb with a filter to simple things up?
Old Oct 26, 2012 | 07:21 AM
  #69
Gary Lewis's Avatar
Gary Lewis
I would leave the return in place. It sounds like you have the hot fuel option, and it won't work w/o the return. And, it won't hurt anything.
Old Oct 26, 2012 | 07:42 AM
  #70
RockWVU's Avatar
RockWVU
Ok I was I guess concerned that it would restrict fuel flow or something on my mild 460
Old Oct 26, 2012 | 08:11 AM
  #71
Gary Lewis's Avatar
Gary Lewis
Don't think it will hurt flow.
speedracer54729
Feb 13, 2008 07:11 AM
str8racing
Jul 17, 2007 09:56 PM
93candycane
Feb 18, 2005 01:15 PM
hawk205
Sep 19, 2004 09:34 PM
jnbutl
Aug 6, 1999 07:11 AM
