fuel tanks
Old Jun 6, 1999 | 10:16 AM
jnbutl's Avatar
jnbutl
fuel tanks
I have an 87 F250 with a 460 and electric in-tank fuel pumps. It runs out of fuel when I switch tanks. Both tanks are full, the fuel pumps in both tanks are working, and the selector valve is new. The fuse is okay also.
Any ideas?
Old Jun 7, 1999 | 11:52 AM
Phillip Guidry's Avatar
Phillip Guidry
fuel tanks
If your engine is EFI, there should be a hi-pressure pump on the frame,along with the low-pressure pumps in the tank.Now,if you can run on one tank only,and both in-tank pumps are working,here is what to check: {1}No voltage to frame pump when selecting inoperative tank.{2}Kinked fuel line from inoperative tank to selector valve.{3}Defective selector switch or wiring.{4}Broken impeller on fuel pump in tank.
Phillip
Old Jul 14, 1999 | 11:52 AM
Ned Little
Guest
Posts: n/a
fuel tanks
I have what I believe to be the same problem that you are having. Both tanks are full and when I switch from one tank to another it runs out of gas. I can then switch back and it still will not run. I have to bleed the mechanical switch located on the left frame just behind the high pressure fuel pump. I was having a fuel pump problem but misdiagnosed it and replaced the mechanical switch instead. Ever since I have been having this problem and haven't been able to figure it out yet. I believe that there must be a way of bleeding this switch that I don't know about but need to do.
Old Aug 5, 1999 | 11:57 PM
Pat's Avatar
Pat
fuel tanks
you might check just to make sure that your "crash" switch under the dash isn't faulty. When my inertia switch went out I had the same problem.
Old Aug 6, 1999 | 07:11 AM
sfsdfsa
Guest
Posts: n/a
fuel tanks
Millam
Nov 10, 2014 10:18 AM
merbno
Oct 14, 2014 05:36 PM
tkisling
Dec 25, 2013 09:47 AM
wifes65
Jul 24, 2008 05:39 PM
mjfitting
16
May 6, 2007 06:14 PM
