What a mess.
Old Oct 4, 2012 | 05:55 PM
StrokinWarmblood's Avatar
StrokinWarmblood
What a mess.
Hello, folks! It's been a while since I posted anything. That's because the ole girl was running pretty decent. Not so much anymore. I've got an 04 F350 SRW, with an auto tranny. First I'll list off the symptoms:
1. When cruising along or accelerating, the vgt spools up and down, up and down.
2. Once in a while the engine will miss.
3. Hard starting.
I'm going to go out on a limb and suggest HPO problems?
Now for the tranny related stuff.
4. When driving down the road, cruise on or off, it will come out of gear for a second, long enough for the rpms to go way up, and then it goes back into gear with a big SLAM.
5. The Tow/Haul light goes solid for a minute, then starts flashing.
6. After that, it shifts at roughly 2200rpm and will not go into O/d.
Here are the codes; I could only find a description for one:
1. p0046: Turbo Boost Control Solenoid Circuit Range/Performance
2. p0275:
3. p2287:
4. p0766:
5. p2703:
In advance, I thank all of you for your help and input. It is greatly appreciated.
Old Oct 4, 2012 | 07:39 PM
bismic's Avatar
bismic
<TABLE style="WIDTH: 291pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=388 x:str><COLGROUP><COL style="WIDTH: 32pt; mso-width-source: userset; mso-width-alt: 1507" width=42><COL style="WIDTH: 259pt; mso-width-source: userset; mso-width-alt: 12288" width=346><TBODY><TR style="HEIGHT: 9.9pt; mso-height-source: userset" height=13><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 32pt; HEIGHT: 9.9pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl63 height=13 width=42>P0766</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; WIDTH: 259pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl64 width=346>Shift Solenoid "D" Performance/Stuck Off</TD></TR></TBODY></TABLE><TABLE style="WIDTH: 291pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=388 x:str><COLGROUP><COL style="WIDTH: 32pt; mso-width-source: userset; mso-width-alt: 1507" width=42><COL style="WIDTH: 259pt; mso-width-source: userset; mso-width-alt: 12288" width=346><TBODY><TR style="HEIGHT: 9.9pt; mso-height-source: userset" height=13><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 32pt; HEIGHT: 9.9pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 height=13 width=42>P2703</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; WIDTH: 259pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl66 width=346>Transmission Friction Element "D" Apply Time Range/Performance</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 291pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=388 x:str><COLGROUP><COL style="WIDTH: 32pt; mso-width-source: userset; mso-width-alt: 1507" width=42><COL style="WIDTH: 259pt; mso-width-source: userset; mso-width-alt: 12288" width=346><TBODY><TR style="HEIGHT: 9.9pt; mso-height-source: userset" height=13><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 32pt; HEIGHT: 9.9pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 height=13 width=42>P0275</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; WIDTH: 259pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl66 width=346>Cylinder 5 Contribution/Balance</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 291pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=388 x:str><COLGROUP><COL style="WIDTH: 32pt; mso-width-source: userset; mso-width-alt: 1507" width=42><COL style="WIDTH: 259pt; mso-width-source: userset; mso-width-alt: 12288" width=346><TBODY><TR style="HEIGHT: 9.9pt; mso-height-source: userset" height=13><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 32pt; HEIGHT: 9.9pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl65 height=13 width=42>P2287</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; WIDTH: 259pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl66 width=346>Injector Control Pressure Sensor Circuit Intermittent</TD></TR></TBODY></TABLE>
Old Oct 4, 2012 | 07:40 PM
StrokinWarmblood
Thanks a lot for the code definitions! Any clue what this all means?
Old Oct 4, 2012 | 07:45 PM
bismic's Avatar
bismic
Shift Solenoid D is probably bad, but I do not know transmissions much at all. I can find you a pic of the transmission that will locate the specific solenoid, but I will have to search for it.
Your ICP sensor may also be bad. Do you know if it is behind the turbo or on your passenger valve cover (04's had it in both of those locations depending on build date). The sensors under the turbo are hard to get to, but they have a fairly high failure rate (and so does the connector for it).
Old Oct 4, 2012 | 07:47 PM
StrokinWarmblood
The icp sensor is on the pass valve cover. I replaced it a month ago hoping it would fix the problem.
Old Oct 4, 2012 | 07:55 PM
bismic's Avatar
bismic
Try this:
Code P0046 is set when a short to ground, open, or short to power is identified in the VGTCV or wiring between the PCM and VGTCV. This circuit is a continuously monitored circuit that takes less than 1 second to set.
Old Oct 4, 2012 | 07:59 PM
BLADE35's Avatar
BLADE35
How about the ICP Pigtail was it changed too
Have any gauges??
Old Oct 4, 2012 | 08:04 PM
BLADE35's Avatar
BLADE35
Originally Posted by bismic
Try this:
with this ^^^ and below
<TABLE style="WIDTH: 681pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=908><COLGROUP><COL style="WIDTH: 77pt; mso-width-source: userset; mso-width-alt: 3730" width=102><COL style="WIDTH: 86pt; mso-width-source: userset; mso-width-alt: 4205" width=115><COL style="WIDTH: 237pt; mso-width-source: userset; mso-width-alt: 11556" width=316><COL style="WIDTH: 281pt; mso-width-source: userset; mso-width-alt: 13714" width=375><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 77pt; HEIGHT: 12.75pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 height=17 width=102>P2287</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 86pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 width=115>ICP</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 237pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=316>Injector Control Pressure Sensor Circuit Intermittent</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 281pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=375>ICP signal is intermittent</TD></TR></TBODY></TABLE>
Kinda is pointing to a wire harness Chaffe IMO
Old Oct 4, 2012 | 08:50 PM
StrokinWarmblood
Wire chaff on the icp harness? I'll look tomorrow and post back. Any particular places I should look?
Old Oct 4, 2012 | 10:27 PM
bismic's Avatar
bismic
Solenoid pics:
Ford Truck Enthusiasts Forums - bismic's Album: TorqShift
Adam Marsh
6.7L Power Stroke Diesel
Sep 3, 2024 10:16 AM
Jmoen7
Mar 5, 2016 07:04 PM
gaer
Mar 13, 2011 10:54 AM
sbowling79
Mar 2, 2010 05:01 PM
vdubin474
Feb 9, 2008 10:29 PM
