F150 AC issue
Old Oct 4, 2012 | 02:57 PM
digitalshooter's Avatar
digitalshooter
F150 AC issue
Definately have a leak, and I think its the evaporator.
Before I disassemble the whole dash, is there anything that will set off my Tif Freon detector when inserted in the AC ducts, other than a leak in the evaporator?
Old Oct 5, 2012 | 11:05 PM
lsrx101's Avatar
lsrx101
I got fooled by liquid air freshener residue once. I was probing the center floor vent on a Buick Century trying to find a very elusive leak, the lowest point in the system. I got a repeatable, solid hit at the vent.
After removing the IP and finding a pristine evaporator, doing a lot of swearing and then thinking really hard, I remembered the bottle of liquid air freshener in the glove box.
The entire carpet on the "hump" between the vent and the seat sent my H-10 detector into orbit.
Aside from something goofy like that, if you're getting a "hit" from the dash vents you've likely discovered your leak.
Try probing the evaporator case drain. A "hit" from there after sitting for a couple of hours is a dead giveaway.
What is the Make, Model and Year of your truck?
Old Oct 5, 2012 | 11:32 PM
digitalshooter
2008 F150 Lariat Supercrew 5.4
Old Oct 6, 2012 | 12:15 AM
lsrx101's Avatar
lsrx101
Hmmm, '08?
The evaporator certainly "could" be bad, but that's pretty young for an evap failure, barring a mfgr. defect.
Unfortunately, diagnosing a leaky evaporator to 90% probability often comes down to ruling out leaks in everything else in the system. I would sooner suspect the compressor body or shaft seals on a system of that age with no other easily detectable leaks.
Try this:
-Cover the snout of the compressor in plastic, a 59 cent shower cap works good. Seal it with duct tape or similar. If you can somehow encase the whole compressor (mounts and all) that would be even better.
-Also wrap any pressure switches and accessible fittings with plastic and seal them off, just to be thorough.
You need to have a good charge of refrigerant in the system, BTW.
Let the vehicle sit overnight then slit open the plastic and "sniff" the contents.
Edit: DUH, I overlooked something very important.
Your 2008 had UV dye installed in the AC system at the factory. Source (rent) a UV light and the necessary yellow glasses and have a look at everything that you can see of the system. Compressor leaks don't always show dye traces, so the "bag" test still applies.
Old Oct 6, 2012 | 12:29 AM
digitalshooter
Originally Posted by lsrx101
Hmmm, '08?
Try this:
Ok. Btw the sniffer has an 18 inch wand and when inserted in the vents goes off. Had sniffed around the engine compartment with no hits. Using the UV light are the yellow glasses really necessary? Because I have looked a3ound with UF light and found nothing. Even added quarter ounce of additional uv detector not knowing any was in there.
Old Oct 7, 2012 | 06:22 AM
lsrx101's Avatar
lsrx101
The glasses really enhance the glow of the dye.
Probe the evaporator drain and see if you get a positive hit. It will be on the bottom of the evap case under the hood, or a short tube sticking through the firewall if the evap is in the case behind the inst. panel. I'm not sure how your 08 is laid out.
BuckHammer
Jul 5, 2011 01:01 PM
Jtanner76
May 24, 2011 11:14 PM
d5332
1997 - 2003 F150
Nov 30, 2010 09:40 PM
thekingofcows
26
Feb 1, 2010 07:11 PM
kennyrandolph
Apr 25, 2009 07:58 PM
