Question about lifting the front end
Old Oct 3, 2012 | 06:51 AM
NW 150's Avatar
NW 150
I've read a few posts about lifting the front ends of these trucks, which include the springs, drop brackets, etc.
My questions is about the c-bushing degrees. On some posts I've read that you use the 7degree bushings for a 6"+ lift. But I just read a post from a year ago that says if you use the radius arm drop brackets, that you use the stock bushings, and not the 7 degree bushings. I need to know what to use, because I bought both the brackets and 7 degree bushings, and need to know if I can return the bushings or not.
Let me know ASAP! I'm going to be installing 6" springs in the spring time, so the geometry will go back to stock from using the springs and the drop brackets.
collinft
Aug 21, 2011 07:10 PM
79Ford4x4
Apr 3, 2010 02:24 PM
tps93ranger
1983 - 2012 Ranger & B-Series
Sep 17, 2009 09:21 AM
Blueoval_boy_64
Offroad & 4x4
Mar 31, 2005 01:07 PM
Erik R
Mar 20, 2003 08:50 AM
