Offroad & 4x4
bushings
Old Mar 30, 2005 | 11:27 PM
Blueoval_boy_64's Avatar
Blueoval_boy_64
bushings
what would be easier? getting ready to put a 78 dana 44 into my 94 F-150. My 94 has a 6 inch kit in it already, and was going to keep the same springs. Would it be easier to put in offset bushings into the radius arms to correct the pinion angle, or fab up some drop down brackets. Also, if I went with some bushings, what size should I get? Thanks!
Old Mar 31, 2005 | 12:18 AM
mustange70's Avatar
mustange70
I would fab up the radius arm mounts, theres a guy around here that went with the bushings and unless he messed up on simething, it didn't turn out all that great.
Old Mar 31, 2005 | 01:07 PM
camo4stealth's Avatar
camo4stealth
If you go with just the bushings, you will be losing some articulation of your radius arms. Also, can the bushings make up for 6" of lift by themselves? I'd seriously consider the drop downs.
ElMoco
Sep 26, 2012 08:12 PM
DIYMechanic
25
May 18, 2012 05:56 PM
Brown Falcon
Oct 20, 2011 09:53 PM
rxtr
1983 - 2012 Ranger & B-Series
Dec 28, 2003 02:04 AM
timinoh
Oct 11, 2002 12:31 AM
