Junker engine project?
Old Oct 2, 2012 | 07:18 PM
chamblizi's Avatar
chamblizi
Hey, Whats up people..... I am prepping to start working on a new project...
I am intending, to buy a junker 351m/400 with good compression and bulk it up....
In my project i am would like to have a hydraulic roller camshaft, performance heads an top notch decent priced rods.
What i would like to know is what is the best recommended by fellow ford enthusiast.
Old Oct 3, 2012 | 12:36 AM
wyoming4x4's Avatar
wyoming4x4
400 stuff
con rods. their are no simple upgrades for con rods that are cheap for the 400. but tim meyer sells a 434" with upgraded kit. usual situation is to ARP everything and polish rods of rough casting and shot peen. several good company's on camshaft applications. i use MPGheads.com custom cam grinder and decent on prices. cylinder heads and application for best reccomendations. several to choose from.
Old Oct 3, 2012 | 05:19 AM
chamblizi's Avatar
chamblizi
i plan to reuse everything on the lower end except the cam.
Old Oct 3, 2012 | 01:43 PM
85e150's Avatar
85e150
Including worn bearings and worn low compression pistons?
Old Oct 3, 2012 | 05:17 PM
chamblizi's Avatar
chamblizi
its a cheap build and virtually anything can be re used except for the scrap parts such as "BEARINGS"
its a nothing special engine build..... i get bored doing 30-35 hours a week at work job change loss of 5-10 hours and loss of 50 cents.... a hour
Old Oct 3, 2012 | 10:49 PM
85e150's Avatar
85e150
If nothing special is what you're after, you are on the right track.
Old Oct 4, 2012 | 01:35 PM
chamblizi's Avatar
chamblizi
i want to throw the little engine on something, idk what but it has to be very low to the ground..... fast... and have a nice roll cage.. i wanna make a ATV or something turn the block sideways and hook up some type of system to attatch it to some type of clutch..... Just to build something.....
just to build something.... I know they got v8 lawn mowers but its been done to much before.
Old Oct 4, 2012 | 03:56 PM
Fordzilla80's Avatar
Fordzilla80
So you want to make a V8 powered go-cart, using a 351M/400?
Good idea, horrible execution. You could go with a 302 and save weight, have a wider range of aftermarket products, and not have an overly large tube frame with a giant motor in it. The 351M/400 isn't a good choice for that kind of project at all.
However, putting a 351M/400 into a tractor is a much better idea.
Of course, a 460 into a tractor is an even better idea.
Old Nov 14, 2012 | 05:26 AM
Foryota's Avatar
Foryota
Call Oregon camshaft grinders they make they best cam. And custom. Just tell them what you want or give them I grind number. There located in Vancouver, Washington. You won't regret it. And it's a great idea! Thing would pull for days with all that torque and no weight. Put it in a trike. Me and my old man built a 347 stroked trike about 5 years ago. Took one run down the road and sold it to my buddy it was stupid fast. 420 hp to the crank. Also had an Oregon cam in her. A turboed vw is always cheap and fun too!
Old Nov 14, 2012 | 05:28 AM
Foryota's Avatar
Foryota
He killed him self 2 years later at portland international raceway.. Rip mike dearmin. Hit the wall at 170 on a gxr 1500 ^^
fozzy
Jul 31, 2008 10:16 AM
78f250_rls
Oct 3, 2005 06:44 AM
mfewtrail
Dec 11, 2004 06:11 PM
1979f_100
Dec 5, 2004 11:23 AM
78custom
Nov 6, 2003 08:31 PM
