using Antifreeze, no leaks...PLEASE HELP
Old Oct 2, 2012 | 02:31 PM
frogman434's Avatar
frogman434
Cool using Antifreeze, no leaks...PLEASE HELP
So here is the issue....Degaus looks like it is puking antifreeze all over inside of engine compartment. Dealer did a pressure test, no leaks....I dont see any white smoke when matting it. It seems to be running rough now when i start it until it gets warm. I see nothing in the oil, it looks good. Thoughts? Is this the early makings of a blown head?
Old Oct 2, 2012 | 02:35 PM
BLADE35's Avatar
BLADE35
pull egr valve inspect chamber for Coolant
Stick a new Degass Bottle Cap on it
Old Oct 2, 2012 | 02:37 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
What year is the truck and any mods?
Dealer probably should have tested pressures while it was running also
http://www.phila.gov/fleet/Warranty%...sb09-08-03.pdf
Old Oct 2, 2012 | 02:38 PM
frogman434's Avatar
frogman434
Sorry i failed to state earlier, I just had the EGR Valve at a cost of 500.00 on my way back from Sturgis, that sucked...Ok i will pop it and look in, what should i not see in there? I will order a new cap. Anything else?
Old Oct 2, 2012 | 02:40 PM
frogman434's Avatar
frogman434
2005 Ford Excursion. I assume they did that, but i did not ask...sigh
Old Oct 2, 2012 | 02:48 PM
SOB Racing's Avatar
SOB Racing
I have blown head gaskes twice, one of the times I found out I also had two cracked heads. If you are puking out of de-gas its usually head gasket but not all the time. I think normal pressure in de-gas res. should be around 5 to 7 lbs. Each time i had puke conditions is was head gasket- (unlucky i guess). Do you have oil or fuel in the coolant system?
Old Oct 2, 2012 | 02:51 PM
frogman434's Avatar
frogman434
I don't believe i have either fuel or oil in the de-gas. I have been in there many times to fill it Looks like just anti is in there....
Old Oct 2, 2012 | 03:40 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Should be dry to a little oily but no coolant/wetness. If you can park nose down and let the truck cool a bit is best time to check. A lot of times exhaust will steam and smell like coolant if EGR cooler is leaking. Head gaskets can leak under high load-temp-rpm-boost conditions and not leak at idle. This usually happens in the beginning and gets progressively worse.
Old Oct 2, 2012 | 03:43 PM
BLADE35's Avatar
BLADE35
well were you using coolant when the EGR Valve wa changed???
If not Pull it again it could have failed recent even yesterday
A failed HG or Failed Will put pressure into the cooling system
The Diff is a failed EGR Cooler will usually cause white smoke
A failed HeadGasket usually Pukes and will have temp spikes but the temp spike will be hard to see on stock gauges
Hows the ECT vs EOT Deltas????
Time for a ScanGaugeII or something
do you run a tunner
Old Oct 2, 2012 | 03:55 PM
amdriven2liv
What is the opinion on this test? (By the way, someone used a tennis ball with holes in it as a stopper)
Bad EGR cooler or head gasket - YouTube
Old Oct 2, 2012 | 04:02 PM
frogman434's Avatar
frogman434
I was using coolant when i replaced the EGR. No tuner, I do have a tester scanII. How do i check temp with that? I have white smoke at start up. I will pull the egr and see what i find inside.
Old Oct 2, 2012 | 04:38 PM
BLADE35's Avatar
BLADE35
What is the ECT vs EOT Deltas??? at 65mph after compleate heat soak????
Old Oct 2, 2012 | 06:07 PM
frogman434's Avatar
frogman434
I can check that tomorrow, i would use the scanII for that?
Old Oct 2, 2012 | 06:36 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Yes you would..... get it fully up to operating temps...get on a long road with a 65MPH speed limit and run for about 10 miles on sorta level road..... no mountains. Then check and note the temps for the oil and coolant.
Before you even start the truck for the first time tomorrow, put the key in the ON position (DO NOT START IT) and check the temps of the coolant and the oil then too....write down those numbers. (Lower right hand button on the Scan Gauge might have to bw pushed to turn the SG on.)
Old Oct 2, 2012 | 07:08 PM
amdriven2liv
Make sure you have the Xgauge programed in for EOT
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F (00090005FFD8 alternate MTH found)
NAM: EOT
And a list of more for future readings of all sorts.
https://www.ford-trucks.com/forums/1...l#post10227382
chewedtoothpick
Apr 20, 2013 03:49 AM
KPBJJ
6.4L Power Stroke Diesel
15
Mar 16, 2013 07:56 PM
9228.bobcat
Aug 11, 2012 10:22 AM
Lucy's Driver
Apr 5, 2010 08:51 AM
Black1
Apr 6, 2007 09:36 PM
