EOT/ECT deltas
Old Oct 1, 2012 | 08:38 PM
BRay09's Avatar
BRay09
EOT/ECT deltas
Well i was playing with a friends scanner. I got my 06 F250 warmed up and took it for about a 20 minute drive. My EOT stayed about 222 while my ECT was at 174. How bad is this? Does this point to a clogged oil cooler?
Also, i had:
FICM logic power- 12.98V
FICM main power- 49.92V
FICM vehicle power- 12.98V
Is this about normal for the FICM?
There was also a U1900 code: CAN communication bus fault recieve error. What does this mean?
What would be the smart thing to do here?
Old Oct 1, 2012 | 08:44 PM
mustang_309's Avatar
mustang_309
FICM voltage seems high and ECT seems low. What is the ECT and EOT after a good cold soak overnight? Check before starting.
Old Oct 1, 2012 | 08:49 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
If temps are correct (check sending units like he said ^^^) you need a new thermostat. The TSB test technically isn't valid unless the ECT is 190*+, but with the EOT hanging out at 222* it's not a promising outlook for the oil cooler.
Old Oct 1, 2012 | 08:52 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Thermostat replacement. ECT needs to be 195 iirc before checking EOT. 20 min of driving should have got you up to full temp. At 222 on this test it ain't lookin good for your oil cooler.
If you can, check EOT/ECT/IAT cold (parked overnight) to verify sensors are reading correct before condemning oil cooler.
FICM looks good but batteries or charging system may be a little low.
TSB 09-8-3
http://www.phila.gov/fleet/Warranty%...sb09-08-03.pdf
Old Oct 1, 2012 | 09:01 PM
BRay09's Avatar
BRay09
Original batteries are getting weak. They are going to be replaced. Have had a couple of " hope it starts" moments... I will check those sensors out in the morning and report back.
Pretty sure I'll be tearing into this thing in the next few weeks for studs and what not. ELC coolant and a new thermostat is on the list.
Old Oct 1, 2012 | 09:02 PM
BRay09's Avatar
BRay09
What about the u1900 code?
Old Oct 1, 2012 | 09:42 PM
Rusty Axlerod
The U 1900 code is above my pay grade right now but it's obviously a data error of some type. I would hit the "clear codes" button and see if it comes back. Sometimes that data stuff just is just a glitch. Have to do some research if it's re-occurring. If your code reader supports freeze frame data (temp, rpm speed etc. when the code was set) make a note of it before clearing the code. If it does come back that info might help chase the problem down.
Old Oct 2, 2012 | 07:51 AM
Misky6.0's Avatar
Misky6.0
My Ex has typically started instantly on cold mornings after letting the fuel pressure and glow plugs do their thing. But starting last week it had that
"weak battery" kind of slow crank and it took +/- 5 seconds or so to fire.
I got two new batteries (Diehard Platinum) on line sale Saturday with
additional $40 off code ($177 each) and now it springs to live in the
mornings again.
Don't keep those weak batteries too long....
Thanks to all the folks @ FTE for the great info!
Old Oct 2, 2012 | 08:07 AM
BRay09's Avatar
BRay09
It's been 55 degrees here. It's not cold enough to affect a decent battery once it was to the point where it killed them enough before it started to shut off all my accessories. They are coming out very soon.
Old Oct 3, 2012 | 05:15 AM
BRay09's Avatar
BRay09
Well I took the truck to work today, a 45 minute drive down the highway. The ECT never got over 180 while oil got to about 212-218. Where's the best place to get a thermostat? Will a parts store be sufficient?
Old Oct 3, 2012 | 05:21 AM
Yahiko's Avatar
Yahiko
I got mine at Ford and the price was not that bad $30ish.
That was with new housing and gasket. All I had to do
was un bolt the old one and bolt the new one back in.
But what ever you do get it changed so you don't
have other problems from the temp being too cold.
Sean
Old Oct 3, 2012 | 08:08 AM
BRay09's Avatar
BRay09
Like 10 mpg/14 highway? Hope this bumps it up some
Old Oct 4, 2012 | 08:39 PM
BRay09's Avatar
BRay09
Well I looked at the sensors after 26 hrs of sitting. After glow plugs cycled, EOT was at 97 and ECT was at 70. Why would the oil temp be reading so high when it's only 66 degrees here?
Old Oct 4, 2012 | 08:47 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Bad oil temp sending unit would be my guess.
danocross
Aug 24, 2020 07:39 PM
stanley6.0
Jun 11, 2016 06:45 AM
oldmanAZ
Oct 20, 2014 11:12 AM
jl4407
Jul 5, 2012 12:23 AM
FordMan35
May 4, 2010 10:22 PM
