source for Ford eot/ect test procedure?
Old Oct 1, 2012 | 04:10 PM
MC5C's Avatar
MC5C
It's been mentioned a few times and once I even saw a snippet of the Ford test procedure - the one that uses a full throttle application rather than the 65 mph steady speed. Can someone go through it for me? I just did a 1250 mile trip in two days towing 7500 lbs that had a lot of full throttle... I was interested to watch the delta's go up and down.
FWIW, after 10 - 15 seconds of 28 psi boost full throttle to crest a hill I would see 3 - 5 degrees difference - once I saw zero, ect and eot of 212 degrees. Cruise control uses way much throttle to go up hills when you are towing.
Thanks, brian.
Old Oct 1, 2012 | 04:19 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
TSB 09-8-3
http://www.phila.gov/fleet/Warranty%...sb09-08-03.pdf
Warm up truck, push the pedal down all the way a few times, the split should stay under 15* through all of this.
bowkill
2004 - 2008 F150
Jul 9, 2015 04:58 PM
77300i6
1997 - 2003 F150
Jul 4, 2011 09:21 PM
bcaughhorn
20
Mar 11, 2011 09:19 PM
870
Nov 21, 2008 05:03 PM
