no throttle response
Old Oct 1, 2012 | 08:58 AM
iowa 7.3's Avatar
iowa 7.3
my truck started right up this morning!
it revved right up on the way to work
but....at the 1st stop sign
it did not want to come out of idle
even with pushing the gas pedal to the floor
it just kept idling for about 5-10secs
and then....slowly....began to rev up
and finally did and then ran fine
any ideas about this problem?
thanks
dave
Old Oct 1, 2012 | 03:55 PM
tjc transport's Avatar
tjc transport
i ain't rite
did you have the throttle pedal recall done?
sounds like a bad throttle pedal.
Old Oct 1, 2012 | 04:12 PM
iowa 7.3's Avatar
iowa 7.3
i did not receive a notice about this
i have 93,000 miles on my truck now
looks like it'd have had problems before now
what was the deal with the pedal?
dave
Old Oct 1, 2012 | 04:52 PM
tjc transport
i ain't rite
poor quality pedal made by a subcontractor.
the recall was around 3-4 years ago, and for i believe the 99 to 03 7.3 trucks.
Old Oct 1, 2012 | 04:57 PM
Franko72's Avatar
Franko72
Molon Labe
What year is your truck? You can replace the Throttle Position Sensor on 99-2000 IIRC. I've replaced mine with a Dorman a while ago. I believe it was somewhere around $45-$50.
Two little bolts and a plug and your back in business.
Old Oct 1, 2012 | 05:53 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
It happens. I am on my third.
Old Oct 4, 2012 | 01:16 PM
iowa 7.3's Avatar
iowa 7.3
truck died today
was headed home to eat
i drive flat and level for about 10 blocks
then pull a gradual hill for about 1/4 mile
was running great until 1/2 way this hill
when it just idled down even tho i was giving it gas
it idled for about 5 sec then died
sat for about 1 min
and after shutting off and restarting about 5x it started
sounded like it was running on 1/2 the cylinders
then smoothed out
and i made it home
now what?
dave
Old Oct 4, 2012 | 02:07 PM
Christof13T's Avatar
Christof13T
Hutch / harpoon mods need to be done. Pickup foot is either missing, cracked, or your screens are clogged.
Xtof
Old Oct 4, 2012 | 03:22 PM
iowa 7.3's Avatar
iowa 7.3
do you have a link to a source that
would explain how to have this done?
thanks
dave
Old Oct 4, 2012 | 03:29 PM
carltonwebb's Avatar
carltonwebb
Have u checked your oil level? Low oil level with cool weather could cause your issue as well.
Old Oct 4, 2012 | 04:03 PM
iowa 7.3's Avatar
iowa 7.3
i'll check the oil level later tonight when i get home
is the pedal recall still good?
also, it sounds like the throttle position sensor is bad
according to the s + s of my truck
so will probably just order one and replace it
did the later trucks have the postion sensor built into the
accl pedal?
also i found this great thread on this topic
https://www.ford-trucks.com/forums/9...ensor-fyi.html
dave
Old Oct 4, 2012 | 07:38 PM
Christof13T
Try the search bar...
Also... one of the first 2 links on this forum are common technical tips that have been gathered... look for the hutch and harpoon mods.
Easy, cheap, effective.
Xtof
aklim
Mar 11, 2019 05:00 PM
Peterbilt376x
Dec 3, 2014 07:10 PM
dixokai
Oct 8, 2009 09:08 PM
nut1605
Jan 26, 2007 03:34 PM
Tekrep
Jan 16, 2004 08:40 AM
