Connecticut Chapter Join Chapter, Leader:
CT Halloween b/s thread
Old Oct 15, 2012 | 07:42 AM
  #406
WADE MMT/PSD's Avatar
WADE MMT/PSD
Former Vendor
Happy Monday CT!!! Golf cart polo, I love it. That looks like a good time
How often can you do that with golf carts?!?!? Have a great day CT!!
Old Oct 15, 2012 | 08:21 AM
  #407
keyul's Avatar
keyul
Originally Posted by Nice Work Truck
Good morning CT
WOW is it warm out.
Kyle hie just uses it as a fire place but all the time.
The firemen said it was cracked, I did not go up to look.
They did have smoke coming out from under the the cap and had to take it off .
They said that the other flue is OK.
Did they take the cement cap off up at the top, is that what you are referring to?
Old Oct 15, 2012 | 08:40 AM
  #408
Nice Work Truck's Avatar
Nice Work Truck
Yes because smoke was coming out from under it.
So I guess that some smoke had gotten outside of the flue and into the brick and block work.
Old Oct 15, 2012 | 09:00 AM
  #409
BlueOvalPlower's Avatar
BlueOvalPlower
Gas hog...
Ughhh suffered at Yankee Stadium watching the boys look more like a little league team at the plate yesterday
Old Oct 15, 2012 | 03:45 PM
  #410
7.3 Rocket's Avatar
7.3 Rocket
Old Oct 15, 2012 | 03:51 PM
  #411
keyul's Avatar
keyul
Ah so he is definitely going to need a new cap at least, probably a new flue as well, and a chimney cleaning. I am assuming that if they said the flue was cracked that it must be near the top.
Old Oct 15, 2012 | 03:52 PM
  #412
keyul's Avatar
keyul
Also, listed some factory allow 15" wheels for f150/bronco in the buy/sell, if anyones interested, would let em go for cheaper to you guys.
Old Oct 15, 2012 | 04:04 PM
  #413
acf6's Avatar
acf6
Header back of in 40 mins. Hope welding works!
Old Oct 15, 2012 | 04:09 PM
  #414
danorules's Avatar
danorules
Welding? You gonna weld nuts onto the studs and then back them out. Or just weld the headers right to the heads, haha
Old Oct 15, 2012 | 04:12 PM
  #415
keyul's Avatar
keyul
Dont think that welding them to the heads would work at all haha
Old Oct 15, 2012 | 04:20 PM
  #416
acf6's Avatar
acf6
Build up stud broken inside and weld nut on
Old Oct 15, 2012 | 04:24 PM
  #417
7.3 Rocket's Avatar
7.3 Rocket
Not with an attitude like that it wouldn't.
Old Oct 15, 2012 | 04:25 PM
  #418
gbroehl1's Avatar
gbroehl1
Did you find someone to try and weld it for you?
Old Oct 15, 2012 | 04:39 PM
  #419
keyul's Avatar
keyul
Na, it really wouldnt. You could try but uh, youd destroy your heads, and probably not end up welding the two together at all. Aluminum to steel, not really gonna work, if at all. Attitude has nothin to do with it chief!
Old Oct 15, 2012 | 04:44 PM
  #420
danorules's Avatar
danorules
Good luck Miles. I have had success with the welded nut method, hopefully you get good results.
Otherwise just caulk the gaps lol
