leaky 351w
Old Sep 30, 2012 | 02:27 PM
spudman89's Avatar
spudman89
leaky 351w
i've got an 89 F-350 with a 351w with 179,000 original miles. the valve covers, oil pan gasket, possible main bearing seals are leaking oil not serious yet but i need to get it straightened out. im also a dairy farmer and time is an asset i dont have a lot of. should i save up some money and do the work myself, or send it to a garage? if i do the work myself what would take a week would take a week of sundays...thats 7 weeks lol and alot of down time for the truck, on the other hand if i send it out im sure labor alone is gonna be costly...any advice or comments would be great, thanx
Old Sep 30, 2012 | 03:21 PM
1_ton_bronco's Avatar
1_ton_bronco
I know its 4-8 hours on oil pan /pump / gasket.. valve covers wouldn't take long except for the passengers side with the intake plenum removal.. id say 1-2 hours on that side.. rear main makes sense to have a shop do it .. but you can do it yourself in 2-4 hours.. so.. let's say about
80 $ hour labor x about 14 or 15 hours.. hm.. make sense to dyi for $1200.. since the parts cost less than $400
Old Sep 30, 2012 | 06:51 PM
spudman89's Avatar
spudman89
hey thank you the oil pans got me a lil nervous because of the cross member of frame, the motors gotta go up a couple inches for the pan to even move cuz it runs right behind the sump, maybe its in front the sump lol i no it cant go backwards because the tranny is in the way n wont go forward cuz of clearances, but am i goin to have any issues with fuel lines or wiring harnesses if i take it up? if there are going to be issues would it make as much sense to pull the motor and put it on a stand? just kind of running through my options ive never really had everything start leaking at once lol
Old Sep 30, 2012 | 07:37 PM
1_ton_bronco
it makes sense to pull the motor for about 2-3 hours labor.. regasket it and throw it back inin.. you'll be out there a few hours for gaskets and the oil pump.... check the mains and crank if you pull the whole motor.. I could do it in a saturday
But you will not have a problem with clearance.. you raise the motor until the intake hits the firewall
Old Sep 30, 2012 | 10:54 PM
minnesotafisherman's Avatar
minnesotafisherman
I had a "new" engine (60,000 original on it) put into my truck earlier this year when the old one went out, had blown piston rings. Before the piston rings went out, I was going to have all the oil leaks fixed on it, Rear main, oil pan, and valve covers. Shop wanted something like $1400 to do all the work.
Then piston rings went out and so they just swapped a new engine and and re-did all gaskets, new oil pan, etc. before it went into mine.
Old Sep 30, 2012 | 11:23 PM
husky390's Avatar
husky390
FWIW, I'd do the intake manifold and valve cover gaskets first. Mine leak and it makes everything else look like they are leaking.
Old Oct 1, 2012 | 12:01 AM
rikard's Avatar
rikard
There is a good chance that the PCV system is not working properly which could be the cause of some of the leaks. Replace the valve and check the hose.
Regards
rikard
kr98664
27
Feb 7, 2016 11:37 PM
bmlawson
Oct 14, 2006 07:24 AM
terrilynn72
1978 - 1996 Big Bronco
Apr 5, 2004 10:20 PM
Franklin2
Nov 28, 2002 12:21 AM
yogurt7905
Nov 21, 2002 07:14 PM
