Regearing questions
Old Sep 30, 2012 | 10:35 AM
650's Avatar
650
Regearing questions
My truck is a 1976 F.250 4x4 with 4.10 gears in it currently and 36in. tall tires. I was thinking about re-gearing the axles in it to 3.54 or maybe even 3.08. My issue is that to just go 55mph I am spinning 2500 r.p.m. in 4th gear and would like to lower that number to about 1800 or so. Anyone else do this or have any recommendations. Also would 3.08`s be too extreme?
Old Sep 30, 2012 | 10:48 AM
mark a.'s Avatar
mark a.
Yes 308 would be too much, even with 3.54's you are going to loose a lot of power. If you are looking for gas milage, unless you drive highways all the time I wouldn't bother unless you have axles to bolt in that already have the gears in them. It's a lot of work to regear from scratch and it won't be cheep either.
Old Sep 30, 2012 | 02:26 PM
smokenchoken's Avatar
smokenchoken
650 if your calculations are correct with 36's and 4.10 gears 2500 rpm would be 65.25 mph sounds to me like you have 4.56 gears(same 36's and 2500 rpm is 58.65 mph)............3.54 gears will give you 54.41 mph at 1800 rpm and your 36's..... i hope this helps you make your choice's........ (basic math equation.... rpm / gear ratio x tire distance traveled in inches / 12 / 5280 x60 = rpm vs gears) i hope this helps
Old Sep 30, 2012 | 03:09 PM
vic_v8's Avatar
vic_v8
why not just go with an OD trans?
Old Sep 30, 2012 | 10:16 PM
410F-100's Avatar
410F-100
a nv4500 swap aint really that cheap or easy ither...
unless uoy know of another standard tranny that bolts up to an fe w/o a special adapter...
Old Oct 1, 2012 | 06:35 AM
garthneddy's Avatar
garthneddy
By the time you have both axles regeared professionally you could have bought a nice od transmission with everything you need to install it, including the adapter.
Old Oct 1, 2012 | 08:34 AM
74 F350 SCS's Avatar
74 F350 SCS
Hi 650-timely posting for me. I too am debating between a gear change and/or an overdrive or gear splitter. I have a 2WD, 460 w/C6 and 4.10. I was thinking of changing to a 3.73, so I still have adequate power, AND may consider adding the Gear Vendor OD unit. I can't seem to find an auto tranny w/OD to replace the C6 that will bolt on. Not cheap but I'll be happier in the long run so maybe it will be worth it.
Old Oct 4, 2012 | 09:09 PM
650's Avatar
650
If I re-gear I think I am just going to get other axles. I have a parts truck out back with 3.54`s already, but just needs gone through.
Well it seems like the 3.54`s should work pretty good for the highway.
I`d love to have a 5spd nv4500. My issue is I`d have to go buy a $300 adapter plate and then try to find a used tranny somewhere and everywhere I look people think the nv4500 trannys are pure gold even if they have 250,000 on them and need a full rebuild, they still want $400 at least.
Heres a perfect article on how to do it for anyone interested. Installing the NV4500 Overdrive Transmission .: Articles
Old Oct 5, 2012 | 07:39 PM
Blue and White's Avatar
Blue and White
Or the tach is off. Either way if you have 4.10's and 36" tires I think that's a pretty good combo. A little RPM won't hurt the engine up to 75 mph or so. Performance and towing ability could get pretty weak with a longer rear gear and fuel economy may not improve much because the engine is lugging hard. An OD transmission of course would be best of both worlds.
Old Oct 5, 2012 | 08:29 PM
1972RedNeck's Avatar
1972RedNeck
What's hard about the NV4500 swap?
Clark made an over drive 5 speed that was sometimes used behind FT's. The FT bellhousing is 7 7/16" while your bellhousing is 6 13/16". The only problem is, OD clarks seem to be like hen's teeth.
Old Oct 5, 2012 | 08:35 PM
montana_highboy's Avatar
montana_highboy
X2 on both counts, i bet your tach is off, 4.10's with 36's @55mph should turn about 2,100rpm, not 2,500rpm.
35's or 36's play pretty well with the 4.10 gearing, @55-65mph they keep the motor right in its powerband.
Garymcd
Jan 20, 2013 07:09 PM
jrod82pa
20
Apr 24, 2011 05:59 PM
HornedFrogHooah
Feb 11, 2010 10:57 PM
Diesel_Dude
Feb 9, 2007 09:15 AM
Orlie
Modular V10 (6.8l)
13
Jul 14, 2005 04:08 PM
