Starting issues 1981 f250
Old Sep 30, 2012 | 04:01 PM
  #31
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by Gary Lewis
Fuel tank senders are notorious for going bad. I might have gotten damaged when you dropped the tank, but are you sure the tank is well grounded? That's a requirement for the gauge to work properly.
I've had the float arm cross the pickup tube and jam, making them fail to work.
As for the tank being grounded, no the tank itself doesn't need to be grounded persay. It's the sending unit that needs to be grounded. The sending unit has two wires going into/out of it.
Depending on which tank it is, you have either Dark Blue/Yellow wire or a Yellow/Light Blue wire, and a black wire.
To check for a bad ground wire at the sending unit, or bad gauge in the dash, use a jumper wire and connect the colored wire to the black wire, in the connector, then go into the truck and turn on the ignition to accessory; making sure the dash selector switch is on the correct tank for testing (Dual tanks).
If the gauge pegs, the gauge and the ground to the sending unit is good, and the sending unit is at fault.
If the gauge doesn't peg, take your jumper wire and connect the colored wire direct to ground.
If the gauge pegs, then you have a groud fault on the black wire.
If the gauge doesn't peg, you have bad wiring to the gauge, a bad selector switch in the dash, or a bad gauge.
Hope this helps.
Old Sep 30, 2012 | 04:17 PM
  #32
Gary Lewis's Avatar
Gary Lewis
Hope this helps.
Thanks for that catch. That's what I meant, but didn't say it correctly.
Old Oct 3, 2012 | 09:38 PM
  #33
Hotel's Avatar
Hotel
Going to check out the fuel gauge tomorrow, got the temperature gauge working the sender was dead, i looked down into the carb today i saw only a tiny trickle of fuel.
cnice_37
Apr 16, 2024 10:16 AM
pwbowman
Aug 16, 2013 05:14 PM
tylert1976
30
Dec 8, 2012 01:07 PM
CaperFord
38
Jan 29, 2012 04:53 PM
75 SuperCab
Jan 13, 2007 12:09 PM
