Dual fuel tank problems
Old May 17, 2003 | 11:11 PM
waver's Avatar
waver
I recently bought a 1987 f150 with dual fuel tanks and gas keeps switching tanks (pumps from rear to front
vice-versa and then overflows out the fill spout on to the ground)and gas will flow from front tank to motor and not rear, or it switches and draws from the rear and won't from the front.
I already put new fuel pumps in both tanks and the fuel pump on the in line and a new fuel cell vacuum unit and fuel relay and new fuel selector switch.
OK yes i have had it.
What is wrong with this fuel system?????
Old May 18, 2003 | 01:11 AM
bigbluetruck's Avatar
bigbluetruck
Yep, they had a recall. I got my 91 taken care of last year, but the recall will only effect your truck if was under 11 years old. I got mine in under the wire. I got a new rear fuel tank and sending unit to boot. I hate to break the news to you but, I bet they turn you down. You might ask the dealer though. The fix is stainless check valves that install inline between the fuel pump and the fuel line at the nipple on the top of the sending unit. I think there are check valves in the pumps but they quit sealing with age. I don't know what the repair valves would cost if you had to buy them. They might not be too bad, they usually sell parts to fix their mistakes cheaper.
I don't think it would be possible to even rig up a fix to get you going again. No matter which tank I would run on the other would pump to the other tank, they never overflowed, so mine never "cross flowed" too much.
Old May 18, 2003 | 10:20 PM
alabamabuddog's Avatar
alabamabuddog
the problem with the recall is it only covers 150,000 miles or X 3 of years /my 92 was out of miles but I knew a girl at the dealership and she got it fixed for me . Its the valve mine was pumping out of the back into the front .
Old May 19, 2003 | 08:05 AM
EPNCSU2006's Avatar
EPNCSU2006
There's not a cross flow recall for '87 year trucks. It was for the newer trucks with high pressure in tank pumps only. I would check the selector valve on the frame. It is operated by pressure from the in-tank pumps, so it could be stuck one way or the other.
j66b
20
Feb 6, 2015 10:41 AM
mike L
39
Nov 23, 2014 09:33 AM
tkisling
Dec 25, 2013 09:47 AM
ZHMMY
Feb 3, 2013 10:22 AM
predaina
29
Mar 29, 2011 07:07 PM
