JBG break lines?
Old Sep 29, 2012 | 12:45 AM
1980 Ford F-250's Avatar
1980 Ford F-250
JBG break lines?
Anyone ever use bronco graveyards prevent breadlines? Are the stainless worth the extra $35? Do they have everything from the master cylinder back?
Thanks in advance!
Old Sep 29, 2012 | 06:31 AM
Rovernut's Avatar
Rovernut
If they are $35 more than Cunifer line then no, I don't think stainless is worth it.
I've never used stainless brake line, but I've worked with stainless a lot and it's generally harder to cut and harder to bend, though for something like brake line the difference may be negligible.
IMO stainless is only worth paying more than for Cunifer if you're going for appearance.
Old Sep 29, 2012 | 06:58 AM
Archion's Avatar
Archion
Veteran: Marine Corps
If you deal with a lot of winter salt/brine like I do, stainless brake lines are very worth it unless you want to replace them every few years. The replacement steel used in lines these days is not good quality. That Cunifer alloy stuff looks nice, but I did get my rolls of stainless cheaper. Stainless is hard to bend though. If I had seen that before, not being into the british car crowd any ore, I probably would have spent the extra on it instead...
Old Sep 29, 2012 | 10:44 AM
1980 Ford F-250
The ones on jbg are all pre bent. Like this: F250 OE Steel 8 Piece Brake line Set
Old Sep 29, 2012 | 06:59 PM
Archion's Avatar
Archion
Thats not a bad price for pre bent, at that, I would go with stainless around here, out your way, personal choice.
andy011
56
Jun 28, 2024 04:29 PM
jedijeb
Nov 24, 2022 11:46 AM
Rusty 57
Aug 8, 2016 04:25 PM
04F150N56F100
24
Oct 30, 2008 01:56 PM
Poulsom
Feb 9, 2005 09:59 PM
