Sponsored by: Real Truck
tire size
Old Sep 29, 2012 | 12:21 AM
bduck84's Avatar
bduck84
tire size
My 2009 F-250 is completely stock. It came with 275/70/18's from the factory. Is this the largest tire I can run without doing any modifications to the suspension? Please help. Thanks in advance
Old Sep 29, 2012 | 10:25 AM
jimlightner's Avatar
jimlightner
275/70-18 tires, this size in load range E is the tallest commonly available A-T tire for 18 inch rim.
I have seen nothing that is taller with a similar load rating.
I have seen 35-12.50 -18 tires in load range D that are about 1.5 inches taller, but only If you can take the reduced capacity, these should fit, check clearances on front axle at full steering lock to verify. Then park truck diagonal across a ditch and look at clearances with suspension compressed. this is a link to a size chart from General Tire on Grabber ATs Grabber AT2
Do some homework, then talk to the guys at your local tire shop.
If you can deal with decreased carrying capacity there are lots of options.
good luckCheers.
Old Sep 29, 2012 | 10:48 AM
bduck84's Avatar
bduck84
Thanks for the help it is very much appreciated
Old Sep 29, 2012 | 12:18 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I run 295/70/18s (34x11.5") that have a 4080# load rating, you don't have to give up capacity just by going to a bigger tire size. You might not find every tire you want in a given size with an E rating, but as long as the numerical load index is 119 or higher you really aren't losing anything regardless of the letter/ply rating.
Back spacing on the wheel is just as important as nominal tire size. 35x12.50s would be a close fit on stock wheels with probably only light rubbing, but if you put them on aftermarket rims spaced out further, you'll need a 2-4" kit depending on how far out you go. 34x11.50 clears stock on stock, 35x12 is probably the theoretical upper limit before variation in manufacturer sizing makes fitment hit or miss.
Old Sep 29, 2012 | 01:51 PM
Quad Racer's Avatar
Quad Racer
Im running 295 70 18 tires on 18 x 9 -12 offset wheels. The tires clear fine and I think 35's will too as their not much bigger than the 295's. Looks wise I wont go any bigger without a small lift.
without the flares.
Old Sep 29, 2012 | 10:30 PM
bduck84's Avatar
bduck84
Thanks guys, both your trucks look great. What brand tire are you running in 295/70/18?
TexasTech, what brush guard do you have on yours. I like the looks of it, its nice and heavy and goes well with the truck
Old Sep 30, 2012 | 11:34 AM
Quad Racer's Avatar
Quad Racer
Thanks they are Nitto Trail Grapplers.
Old Sep 30, 2012 | 12:20 PM
2000silverbullet's Avatar
2000silverbullet
Not sure if the wheel wells are any different from the '09's to the '11's, but I'll throw in my .02.
285/75-18 (which amounts to 35x11.50) on stock rims. Truck has a 2 1/2" leveling kit, but it would most likely clear @ stock height.
You can see the mark on the radius arm where it barely rubs. I can't feel it all in the wheel when it does though..
Old Sep 30, 2012 | 01:08 PM
texastech_diesel
Token Redneck
Front end replacement is a Ranch Hand Legend:
2007 Ford F250 Legend Front Bumper
Tires are Nitto Trail Grapplers, same as Quad is running:
Mike1
Jun 1, 2017 10:37 AM
dnkensinger
Jan 27, 2015 08:58 PM
4x4slik
Jul 13, 2014 08:03 AM
mattsautobody442
2004 - 2008 F150
Aug 12, 2011 06:25 PM
bigFAWKINranger
Jul 12, 2002 01:58 PM
