coolant questions
Old Sep 28, 2012 | 11:34 PM
Ashton_1012's Avatar
Ashton_1012
coolant questions
Hello
So today i decided to change my thermostat because i thought my old one might be bad. I went with the 195 fail safe for my 390.
my truck ran around 150 constantly, except when i idled it would rise pretty fast. that is why i changed the thermostat. now that i have the new one, the truck runs around 190-200 constantly :/ and it still rises in temp but not as fast.
So question number one is does the thermostat affect how hot your engine runs?
Q-2. How do i know if the new one is working?
Q-3. What do your old 390's run at?
Q-4. I have never used antifreeze coolant.... doesnt freeze where i am. I was told dont do that anymore... so what would be the proper amount to put in it?
Thank you!
Old Sep 29, 2012 | 05:30 AM
jowilker's Avatar
jowilker
These old trucks wont sit & idle long without getting hot, keep it moving 20 mph & you can pitch the fan. 180º T-stat is what it was designed to use. It opens at that temp,
I have lived in North Carolina all my life where it freezes. 50/50 mix is recommended here. Don't know what would be correct for a no freeze zone.
Sounds like the old T-stat was working properly. I don't sweat the gauge setting too much as long as it stays the same.
John
Old Sep 29, 2012 | 07:56 AM
f100today's Avatar
f100today
50% anti freeze with 50% distilled or RO water and add two bottles of Water Wetter. You will be OK.
Old Sep 29, 2012 | 10:08 AM
Ashton_1012
thanks guys, sounds like im in the clear. my engine is performance built, think i should hop back down to the 160 tstat? I believe thats what was in there before and all autozone carried was the 195 fail safe and the 160.
Old Sep 29, 2012 | 12:06 PM
willowbilly3's Avatar
willowbilly3
Anti freeze is also called coolant. The thermal conductivity on glycol based coolant is a little less than straight water but it also has all the rust and corrosion additives, plus it raises the boiling point. Every engine I ever ran on straight water turned to an ugly rusty mess real quick and often the water pump took a dump in short order too.
Water wetter is good.
Old Sep 29, 2012 | 07:28 PM
jowilker's Avatar
jowilker
180º not 160.
John
DJayAce
2004 - 2008 F150
Nov 28, 2016 05:12 PM
orange57
Jul 30, 2016 04:11 AM
IT_Dude
Jan 11, 2011 08:36 AM
roree
Aerostar
Dec 23, 2007 01:07 AM
EHAnderson
1983 - 2012 Ranger & B-Series
Nov 5, 2002 07:12 PM
