Intake/exhaust
Intake/exhaust
If I add the 6673 air filter and put on a aftermarket exhaust must I do a tuner at the same time? I ask because the local diesel shop recommended I have him install the bully dog system with the exhaust. Well money is a bit tight so I plan to install the intake, exhaust, and maybe even a set of airbags on the back axel. The bully system he recommended was like $750 installed and I would just rather wait a while before I spend that much money. So do I HAVE to install a tuner right away or can I wait until money is more accessible?
Hey Jamie.
Do the 6637 and muffler delete for now if you are pinching pennies at this time. You will be happier with custom tunes for your truck. I don't remember if you told me where you live. If you are close, you could come to my shop and we could install the 6637. I have 3 new sitting on my shelf with a piece of black 4" exhaust pipe to install it.
Yeesh... your guy is not looking after your best interest.
- You don't need to chip just because your truck can breathe
- Bully-dog is one-size-fits-all. Pleh. You might appreciate a less-expensive unit that's dialed to your truck - when you're ready.
on
Jamie:
Follow the advice here on FTE...it has come at great expense as well as time investments. 6637, do it! Opening up the exhaust with either a muffler delete, straight-thru muffler, or 4" system...do it! Sell your Superchips programmer, and buy gauges. Then, when YOU are ready financially, buy a real chip/programmer. You will thank FTE for all of this later. AND, it's not about "Our way is the only way," or "you aren't cool if you don't do it our way." It's the tried-and-true "safe" way to get your truck to run well without potentially causing costly issues down the road.
If you are looking to build the biggest, baddest hot rod truck on the road...well, then guys here can help with that too, but that's not the common motivation on this site.
Too many distractions... you posted before I hit "Enter". Superchips? I've heard good things about those. Again... when you're ready, there are other options.
Do you have gauges?
Received 3,230 Likes
on
Only gauge I have so far was installed prior to me buying the truck. It's a transmission temp gauge. All well and good except the gentleman that had the truck didn't install it well in my opinion. It works when it wants and not at all at times so I do not trust it at all. I'll be replacing it soon and start installing the other gauges I need as I get the time and funds. What gauges do I need and what should be priority?
on
priority is an exhaust gas temp gauge, otherwise known as a pyrometer.
a boost gauge is nice to have too, but really all you need is a pyrometer.
i have a stock trans temp gauge in the dash. it is good enough for my needs.
in my pillar 3 pack i have a boost, EGT, and air pressure gauge for the onboard air.
Yeah, skip the Bullydog garbage. I had one on my truck prior to getting a CUSTOM tuner. My DP-Tuner BLOWS the Bullydog out of the water in every way.
The only thing the Bullydog is good for is the gauges it offers and thats about it.
Like everyone else, put on the air filter and exhaust, then save up for a gauges and last, a custom tuner.
You will thank us later...
My signature is a den of links - click around.
There are two chips that the "big boys" play with:
Canned tunes are like watching a political ad on TV this year... plenty of show, but you're left wanting on the go.
- The TS chip, which has an army of good programmers.
- The Moates chip, used by DP Tuner.
