Steering gear leak ?
Old Sep 28, 2012 | 11:25 AM
RA31925's Avatar
RA31925
I've got a pretty bad power steering fluid leak ... somewhere. It leaks slightly when the engine is not running, and a lot worse when it is running. The reservoir will drain itself dry after a few days of sitting, or a few hours of the engine running.
Not to worry, I've been keeping up with the fluid level ... but it makes a heck of a mess under the truck.
I replaced the pump and the pressure and return hoses about a month ago. I drained the system (cooler and steering box) completely and refilled with ATF, since that was what the pump manufacturer recommended.
Replacing the pump and hoses doesn't seem to have made any difference ... something's still leaking badly. I concluded it was something in the steering gear itself, but I can't really tell where (and it wasn't obvious when I had the pump out, either).
Is there a likely source of the leak?
How difficult is it to replace the steering gear? Or is it possible for me to replace its seals?
Old Sep 28, 2012 | 12:56 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Check the seal where the pitman arm shaft comes out of the steering gearbox.
Also check where the steering column lower shaft and/or rag joint connects to the upper steering gearbox shaft.
Both of those seals can fail causing severe leaks.
If the box is as old as the truck, and it's leaking, I would swap a rebuilt unit in there...
Old Sep 28, 2012 | 02:27 PM
Franklin2's Avatar
Franklin2
Just clean it up really good with some brake cleaner, and check to see where it's coming from. They also like to leak from the cooler which mounts on the front of the crossmember. This just looks like a metal line coiled around(that's all it is really) but it likes to rust out on the bottom.
Old Sep 28, 2012 | 02:53 PM
kraylake's Avatar
kraylake
my 1980 F350 400 cid was leaking where "F150" above described. It was a simple and cheap seal replacement.
Old Sep 28, 2012 | 03:06 PM
regbl10's Avatar
regbl10
I'm replying to this thread to find out how to post a new post or thread. Your help will be greatly appreciated.
regbl10
Old Sep 28, 2012 | 03:23 PM
ctubutis's Avatar
ctubutis
regbl10
We have Testing forum for that, ya know....
Testing..... - Ford Truck Enthusiasts Forums
DieselCamper
6.4L Power Stroke Diesel
May 30, 2016 07:55 AM
WoomaHodal
Jul 17, 2009 05:35 PM
captainl67
1978 - 1996 Big Bronco
Aug 11, 2006 11:22 PM
tractoman
Feb 21, 2006 02:25 PM
superbepro
Jul 24, 2004 05:16 AM
