Traction Beam To Solid axle
Old Aug 29, 2002 | 11:47 PM
MJD's Avatar
MJD
I was thinking about using an older F-250 for a project. I would like to convert the forntend to a solid axle, but keep it reasonably low to the ground. It doesn't look like it would be that hard. i would like to keep it relatively cheap.
Old Aug 31, 2002 | 10:33 PM
Greg Carter's Avatar
Greg Carter
You can find all the information you need in the link in my sig. Your biggest cost is going to be to locate a Danaa 60 from an F-350.
Old Aug 31, 2002 | 10:45 PM
200tq's Avatar
200tq
That's funny. Good luck. If you can touch a D60 front for under a grand I'd be impressed.
Be different, weld the D50 TTB together to create a solid axle
Old Sep 1, 2002 | 12:09 AM
orange peel's Avatar
orange peel
im doing the same swap, im going to use leaf springs up front because that seems a bit easier and cheaper than dealing with coils and all.
Old Sep 1, 2002 | 12:13 AM
orange peel
Greg, was your truck already leaf sprung up front?
Old Sep 1, 2002 | 10:05 AM
200tq's Avatar
200tq
Yes. If you read his article and look at the pics it's clear. It was an F250 w/D50 TTB and he dropped in a live D60 front. Again, look at the pics.
Old Sep 1, 2002 | 10:37 PM
Greg Carter
Yes, I believe all F-250s of this generation were.
And yes finding a Dana 60 is going to be hard for cheap. The best way is to forget junkyards (at least the large well run ones), because they wont let them go for less than $1000. Try to find someone parting out an F-350, or look for a wreched on in the local Truck Trader.
Old Sep 2, 2002 | 09:29 PM
orange peel
i looked and read the article but it still confusing to me because i didnt know that there was a leaf sprung TTB, even if it was a 250. so my swap should be farily easy to do then. all i need to do is get spring hangers welded on in the right spot and the rest of the swap should be farily easy. i have a little more confadence in my idea now.
Old Sep 6, 2002 | 10:48 PM
MJD's Avatar
MJD
Thanks alot for the advise.
Old Sep 9, 2002 | 12:24 AM
Brian460's Avatar
Brian460
I would suggest bolting the hangers on as you are not suppose to weld to these frames.
Old Sep 9, 2002 | 03:38 PM
orange peel
why arent you supposed to weld the spring hangers to the frame? thats what my plan was
Old Sep 9, 2002 | 04:17 PM
honney's Avatar
honney
IMO that's a myth. You can weld to the frame. I've had a set of rear hangers welded to my '90 frame for a couple of years, no problems. In theory the heat causes the frame to lose it's temper, in practice I dunno that it's really an issue. If you're worried about it weld short beads to keep the heat down.
Old Sep 9, 2002 | 10:50 PM
orange peel
so when i put the spring hangers under my truck should i just use 2 grade 8 bolts to put them up?
Old Sep 9, 2002 | 11:26 PM
Brian460's Avatar
Brian460
I would suggest that you attached them with grade 8 bolts in the locations where the Ford Factory would have used rivets. This will also make it easier to replace a bracket if the need should arise.
Old Sep 10, 2002 | 01:13 AM
stoab's Avatar
stoab
scl009
Dec 4, 2018 09:09 AM
hdtraveller57
26
Feb 19, 2017 08:42 AM
DBD7
48
Jul 27, 2014 06:14 PM
buckinbronco'95
1978 - 1996 Big Bronco
May 24, 2009 08:12 AM
johnny6958
Mar 9, 2006 10:19 AM
