93 F-150 axle swap
93 F-150 axle swap
I am considering swapping a solid axle for my ifs. I have a 93 150 Super cab. I want to lift the suspension later and I have found that when you lift the ifs it looks like a plane with the landing gear folding in. The only correction I can think of is to swap out the axle for a solid unit. Any help would be greatly appreciated.
an SAS will require a minimum of 6" of lift period so that is out for you. to fit 33's on that year a minumum of 4" lift will be needed. leveling coils may work but you will have to move your front bumper out and remove the lower plastic piece thats on the bumper as well. even still it may still rub at full compression. 32" tires would fit no problem
bullnose83
06-17-2015 08:04 PM
alwaysmessedup
06-16-2002 02:08 PM
Dan Mac Donald
Offroad & 4x4
01-10-2000 04:50 PM
