13 cummins
Old Sep 27, 2012 | 11:47 AM
twfish's Avatar
twfish
13 cummins
Don't know if its been heard but ram just released that the 13 cummins will be making 850 lb-ft. So expect around 425 HP and around 850-875 lb-ft with the 6.7 for 2013 or 2014
Old Sep 27, 2012 | 01:40 PM
2ndStroke's Avatar
2ndStroke
The 13 cummins is 385 hp/850 tq
Old Sep 27, 2012 | 02:08 PM
UGA33's Avatar
UGA33
What are they doing to their automatic to hold that?
Old Sep 27, 2012 | 02:13 PM
2ndStroke's Avatar
2ndStroke
Some new 6 speed, called aisin I believe.
Old Sep 27, 2012 | 06:11 PM
Brandon Bloomquist's Avatar
Brandon Bloomquist
Aisin is a very commonly used transmission supplier.
Old Sep 27, 2012 | 06:17 PM
montey2005's Avatar
montey2005
all great but the resale value is still dreadful. I wish them luck but I'm keeping this 2012 6.7
Old Sep 27, 2012 | 07:27 PM
rickatic's Avatar
rickatic
Does it use DEF? If so...might one find it's way into my drive???? I do hear they have a warranty...and a decent HPFP...
Regards
kper05's Avatar
kper05
I thought they were going to DEF or was this in 2014?
Edit: I just realized their website is 2012 specs that states no def.
Old Sep 27, 2012 | 07:30 PM
UGA33's Avatar
UGA33
'13 Cummins will use DEF.
Old Sep 27, 2012 | 07:37 PM
senix's Avatar
senix
I heard that for 2013 they will go DEF. Prescious metals are forcing the change. Since this will be a first year run with DEF I would wait a bit before I would even consider it.
Old Sep 27, 2012 | 07:54 PM
kper05's Avatar
kper05
I could only find forum postings reporting yes for the 2013 and this:
Just 2012 stuff on the RAM site.
Old Sep 27, 2012 | 08:07 PM
senix's Avatar
senix
An article about the 2013:First Look: 2013 Ram 2500/3500 HD - PickupTrucks.com News
Old Sep 27, 2012 | 08:40 PM
montey2005's Avatar
montey2005
I hope they put in man sizes fuel tanks instead of the puny shift we got
Old Sep 27, 2012 | 09:03 PM
UGA33's Avatar
UGA33
They have been running DEF on the C&C trucks for two years now. Shouldn't be a bad launch you would think.
Old Sep 28, 2012 | 05:53 AM
mebe2k's Avatar
mebe2k
atleast they are not putting the DEF tank outside the frame rail behind the front passenger wheel like the GM trucks.. I have seen a few of the new GM trucks with a big black plastic tank behind the front passenger tire..of all places, why there?, and where do you add the DEF?? under the hood? or is there a fill port somewhere on the pass. door frame?
I'm sure when Dodge starts using the SCR system in their pickups, it will work fine, since they've been using it a while on the cab/chassis models like UGA33 mentioned..I do like the Cummins since they are inline 6 engines..just not too fond of the trucks that they come with.
