IDing spindles
Old Sep 27, 2012 | 06:24 AM
Isthisonthetest's Avatar
Isthisonthetest
IDing spindles
I have a set of spindles and calipers off an unknown 60s-70s F series I need to put a name to. The spindle casting numbers are:
7-ED and C303
8-ED and D123
I found some part numbers for 7-CD and 8-CD but not the EDs. The caliper doesn't seem to correspond to any particular model. The ID of the kingpin bushings is .862 though that seems to cover multiple king pin sizes.
I took some pictures but didn't really know what to look for outside of any numbers I could find:
http://imageshack.us/a/img16/2727/picture247custom.jpg
http://imageshack.us/a/img10/4396/picture250custom.jpg
Old Sep 27, 2012 | 10:01 AM
HIO Silver's Avatar
HIO Silver
By the cast steering stop (the protruding nub on the lower trailing side), 'looks to me like a 76-79 assembly.
Old Sep 27, 2012 | 11:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The spindle casting numbers are: 7-ED and C303 / 8-ED and D123
Welcome to FTE
Marked: 7-CD or DD = Ford part number: D5TZ-3105-A (replaced D3TZ-3105-A) .. Right Spindle.
Marked: 8-CD or DD = Ford part number: D5TZ-3106-A (replaced D3TZ-3106-A) .. Left Spindle.
Applications: 1973/74 F250 Regular Cab with 6900 GVW (without 460 engine) / 1975/79 F250 Regular Cab with 6,200 & 6,900 GVW's.
Marked: 7-ED = Ford part number: D5TZ-3105-B (replaced D3TZ-3105-B) .. Right Spindle.
Marked: 8-ED = Ford part number: D5TZ-3106-B (replaced D3TZ-3106-B) .. Left Spindle.
Applications: 1973/79 F100 & 1975/79 F150 / 1973/79 F250 with single piston caliper disc brakes.
Old Sep 27, 2012 | 05:41 PM
Isthisonthetest
Looks like you were right, depending on the model.
*exactly what I needed*
Thanks ND. As I was searching around for the answer you came up in just about every thread with what they needed to know so thanks for being one of the anchors that make forums such a great resource.
ReyTs66Ford
May 16, 2023 09:00 PM
1977F250XLT
Jun 7, 2015 05:48 AM
AlsRyd66
Mar 26, 2015 03:57 PM
thatone
Jun 12, 2012 10:36 AM
'66BlueBlood
Feb 27, 2011 04:12 PM
