Starting the sheetmetal work
Use the power and wire feed speed setting recommended for the metal thickness on the machine, not more than one metal thickness setting to either side and vary the wire stick out (1/4 -3/8" is ideal, never more than 3/4") and torch movement speed to adjust penetration. Butt seams should be tight together, never wider than the filler wire diameter. Using a copper or aluminum backer pressed tight to reduce blow thru. Filler wire should not be thicker than the metal.
rsh1966
18
07-04-2018 07:12 PM
Indybeer
13
08-30-2012 07:54 AM
19fifty4
15
10-02-2008 02:07 PM
codys50ford
10-01-2007 10:40 AM
jack71
01-29-2006 06:54 PM
