Engine dies and steering locks while driving
Old Sep 25, 2012 | 10:15 PM
Moabmike's Avatar
Moabmike
My 1993 f150 occasionally dies while driving and the steering locks up. I'm not sure where to start looking. Any ideas. Thanks
Old Sep 25, 2012 | 11:05 PM
Spktyr's Avatar
Spktyr
Sounds like you have a problem with your ignition switch (which is actually mounted on the bottom of the column) and/or the linkage between it and the lock cylinder (where you put the key). Search the archives for info on servicing or replacing the steering column.
Old Sep 26, 2012 | 06:33 AM
bashby's Avatar
bashby
Does the steering actually lock up (doubtful) or just get really hard to turn? When the engine stalls you will lose your power assist but you can still turn it. Does it start right back up? What engine/trans do you have?
Old Sep 26, 2012 | 07:08 PM
Moabmike's Avatar
Moabmike
The steering actually locks up, just like if the ignition was turned off
Old Sep 26, 2012 | 07:16 PM
Moabmike's Avatar
Moabmike
It is a 5.8l Aod. When you come to stop, an put it in drive, it will start right up
Surfkings
Sep 30, 2018 11:06 PM
terry5048
1983 - 2012 Ranger & B-Series
Nov 20, 2012 03:10 PM
truckalpers
1997 - 2003 F150
Nov 8, 2005 04:11 PM
Phobia16V
13
Aug 10, 2003 09:31 PM
bigpumpkin
Dec 13, 2002 04:01 PM
