Locked Steering Column
Old Sep 29, 2018 | 11:15 AM
Surfkings's Avatar
Surfkings
I have a '55 F100 with a newer steering column (tilt/power steering) and can't find the key - the truck has been in a barn for over 10 years and it's now time to finish the restoration. I am assuming that the key is lost and need to get it out of the Barn which requires me to put the truck in neutral and to be able to steer it out. Any good insight on how to unlock the steering column without trashing it? Can I disassemble the column and remove the lock/locking mechanism? Is this easy? What are my alternatives?
Old Sep 29, 2018 | 02:13 PM
tinman52's Avatar
tinman52
Welder User
GM columns you can remove the lock cylinder if you remove the steering wheel and lock plate. Not sure about other brands.
Check youtube for a video
Old Sep 29, 2018 | 03:44 PM
Surfkings's Avatar
Surfkings
Gracias TinMan...headed to the Farm tomorrow and will give it a shot.
Cheers!
Old Sep 30, 2018 | 09:34 AM
petemcl's Avatar
petemcl
I would just call a locksmith as you will want a key eventually.
Old Sep 30, 2018 | 01:14 PM
tinman52's Avatar
tinman52
Welder User
On most GM columns it's simple to pop the old lock cylinder out and pop in a new one w/key.
Lock smiths are expensive. I use them only as a last resort.
Old Sep 30, 2018 | 02:30 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Besides it would be a lot cheaper to take the column to the locksmith if you can't remove the cylinder th as n having him come to you and do it in the truck. But as Scott said they come pretty easy.
Old Sep 30, 2018 | 04:06 PM
petemcl's Avatar
petemcl
I guess that it all depends upon the model year of the GM column. This video shows some of the pitfalls and special tools needed on a 1998.
Not much easier on a '78 model GM column but at least he shows the tab that must be depressed.
Maybe cheaper as long as you don't break something and as long as you have the special tools.
Old Sep 30, 2018 | 09:46 PM
truckeemtnfords
Maybe I took it for granted that I have them and I'm a Ford guy.
Old Sep 30, 2018 | 11:06 PM
tinman52's Avatar
tinman52
Welder User
Maybe Pete just likes to argue. Seems to be a common theme.........
Dr G
Nov 25, 2009 05:13 PM
46parts
1947 and Older Ford Trucks
Jul 9, 2008 12:59 PM
ozark1
Nov 28, 2006 09:24 PM
gfwelsh
Sep 23, 2006 01:20 PM
oldsmobileguy
1983 - 2012 Ranger & B-Series
Feb 2, 2004 11:16 AM
