2000 power steering
Old Sep 25, 2012 | 01:53 AM
yorky's Avatar
yorky
2000 power steering
I have a 2000 Exploder xls 4.0l vin x. I had the power steering pump and the rack replaced (i did the pump myself also 3rd pump since the problem stays the same and there remans). Now when at a rpm 1500 or above the steering wines like the pump is bad, but at a low rpm 500-1000 you can hear a pin drop. anyone have a idea what this could be? also if you look at/in the reservoir turn the wheel and raise the rpm's, while turning the wheel it looks like there is a vibration since the fluid will splatter real fine drops of fluid untill rpms come back down, or when the wheel is returned to remove any pressure. the sound is like a combination of grinding and your normal steering wine when the pump is bad. i believe all air is out of system, i checked it multiple times and the fluid don't foam or show signs that it wants to
Old Sep 25, 2012 | 06:24 AM
shorod's Avatar
shorod
Welcome to the forum!
It sounds like there is still air in the system. Fortunately I have not had to fight this, but I've read of others here who have. You should search the forum for keywords "power steering". I seem to recall some filter that could be the issue as well, but I don't recall what years that was used on.
-Rod
Old Sep 25, 2012 | 07:29 PM
sorg76F250's Avatar
sorg76F250
I thought my power steering pump was making noise
For years I thought it was the pump. Turned out to be the idler pully. I have '98 5 liter, so it might be different than yours. But it was at the bottom left,no tension spring. Sounds like a new motor now.
frostysdriver
Jan 11, 2011 10:49 PM
AutoAppearancesInc
Aerostar
21
Feb 19, 2009 12:30 PM
bryced_1
1978 - 1996 Big Bronco
May 8, 2005 09:59 PM
bigbadford78
Apr 25, 2005 12:36 AM
Lane Dexter
Oct 3, 2004 11:52 PM
