I have a 1978 supercab 4x4 frame ,engine(400)all the drive train
I was told the motor runs and I need to know what I would have to do to get it to start The engine wire harness is all their .Everything was unpluged from with fire wall so this is all the wiring that I have to work with
I hooked everything up and she turned over great and surprisingly it runs good too. It has visiable leaks from the oil pan and the valve covers but for a 100.00 for the whole working drive train and engine does not seem that bad
thanks for your help
I will pry be posting somemore question soon
