engine starting question
Old May 17, 2003 | 09:23 AM
78blueford's Avatar
78blueford
I have a 1978 supercab 4x4 frame ,engine(400)all the drive train
I was told the motor runs and I need to know what I would have to do to get it to start The engine wire harness is all their .Everything was unpluged from with fire wall so this is all the wiring that I have to work with
Anyinfo would be great thanks
78blueford
Old May 17, 2003 | 09:40 AM
73Custom's Avatar
73Custom
I'll take a stab at it...
- battery grounded to engine
- starter solinoid (which is grounded through it's mounting bracket)
- ignition module with power to the red wire in the two wire connector.
- power to coil, best if through ballast resistor, 12v can burn it out
- fuel supply
Should do it - that's all I can think of...
Marty
Old May 17, 2003 | 04:44 PM
78blueford's Avatar
78blueford
I will give it a try and write back with some info
does the ignition module have to be grounded in any way???
thanks alot
78blueford
Old May 17, 2003 | 04:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
The OEM ignition module gets it's ground from the black wire grounded in the distributor. Some poorly made aftermarket modules must be case grounded.
Old May 18, 2003 | 01:34 AM
78blueford's Avatar
78blueford
thanks for the info guys I will try to get it started on sunday
I will be back with some info sometime sunday night
thanks
again
78blueford
Old May 18, 2003 | 07:34 PM
78blueford's Avatar
78blueford
I hooked everything up and she turned over great and surprisingly it runs good too. It has visiable leaks from the oil pan and the valve covers but for a 100.00 for the whole working drive train and engine does not seem that bad
thanks for your help
I will pry be posting somemore question soon
thanks
78blueford
